Poly windows
Poly windows
Going to Polycarbonate the windows on my E30.
Just want to make sure before it is ordered.
Thickness, will 3mm be ok or will i need thicker?
Thanks in advance for any info.
Retro Al, i was just going to drill and rivet the windows into the original lip that the rubber used to sit on....
Not sure if 3mm will be thick enough to stop it just flexing about all the time.....
i've just fitted some to my xr2 i did away with the window rubber and riveted them to the car .
the stuff they were made out of was plexiglass ( same as used in police riot shields )
i got the from plastics4perormance .
will dig out the number if you want it
chowfornow
14
05-01-2019 09:01 PM
