stalling when i stop!!
Old Aug 23, 2006 | 12:46 PM
lammylama's Avatar
lammylama
Default stalling when i stop!!
i have just got my car going after doing a head gasket etc and when i started it last night it ran spot on but when i stop the revs go so low that it stalls most of the time,but when it settles it ticksover perfectly. The only thing different is i have fitted a bd10 on the inlet side but this shouldnt make any difference i dont think. Do i need to adjust the idle control valve?????......any ideas.
Old Aug 23, 2006 | 01:20 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Can't help you sorry
When are you going to get it set up ?
Steve.
Old Aug 23, 2006 | 01:28 PM
James's Avatar
James
All i would suggest is reset the ecu by unplugging it for about 15 minutes then take it on a steady driver to re-learn it's values.
I've done the same and mine is doing the same as yours, although mines not a cossie, i've done the above and now it seems fine.
Old Aug 23, 2006 | 01:35 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
This don't work on a cossie.
Steve.
Old Aug 23, 2006 | 01:42 PM
James's Avatar
James
oh right.
thats that idea fucked then!
Old Aug 23, 2006 | 02:03 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you need to set the base idle speed by setting the air bypass with the bleed screw with the engine hot and the ISCV unplugged.
Old Aug 24, 2006 | 02:12 AM
ford-driver's Avatar
ford-driver
this might be of some help for ya . . .
https://passionford.com/forum/viewto...light=#3123566
Old Aug 24, 2006 | 06:46 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Off topic a bit but did you get / find a .63 housing ?
Steve.
Old Aug 24, 2006 | 05:04 PM
lammylama's Avatar
lammylama
Steve.
yes i was lucky ...i called a place today and the guy had just taken one off of his car this morning so i got it for a Ł100......
Old Aug 24, 2006 | 05:10 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
You need to set the car up fitting the bd10 is the problem
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DAZZER
Sep 30, 2015 08:43 PM
jay030787
Sep 18, 2015 04:38 PM
Fudgey
Sep 17, 2015 01:06 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
