cosworth envolvement in the scoobs
New T25 scoob
Cosworth Cylinder Heads
Enlarged Intake and Exhaust ports.
Large diameter stainless steel intake valves.
Large diameter Inconel exhaust valves.
Hi Rev valve springs
Titanium Retainers
Hardened Steel spring platforms
Reshaped combustion chamber
Flow bench proven design
Dyno tested
Intake port 14.63% (average) 22% (max) increased flow
Exhaust port 30.56%(average) 41% (max) increased flow
Machined Cosworth Logo
Multi angle valve job
Type-25 Unique Camshaft profiles
Cosworth Assembled Short Engine
Cosworth Forged Rods
Cosworth Forged Pistons
Cosworth High Performance Bearings
Cosworth Unique Engine Number
Unique blue-printed engine build sheet
Assembled by Cosworth race technicians
Cosworth Multi Layer Metal Headgasket
Type-25 Milltek Twinscoll Manifold
Twinscroll Pulse Conversion design
Ceramic Coated inside and out for heat retention/shielding
Type 304 aircraft grade stainless steel
Mandrel bending ensures smooth flow
Type-25 Garrett GT Turbo
Ceramic Coated Exhaust housing for heat retention/shielding
Dual Garrett Ballistic Bearings for instant response
GT Advanced Blade Aerodynamics
Port Compressor Shroud to eliminate surge
Large Inlet
Type-25 Inlet manifold spacers
Increases inlet manifold capacity
Reduces heat transfer from block
Allows larger inlet pipe to be fitted
Type-25 Larger Turbo Inlet pipe
Larger diameter Turbo inlet
Tough silicone construction
Subtle Matt black OEM finish
Up rated filter in standard OEM Intake
Powerstation Re-Programmed Standard ECU with advanced additional features
Unique Dyno calibration on each car
Type-25 Milltek Exhaust system
100 Cell Sports CAT
Large centre silencer
Unique downpipe with Built in silencer
Ceramic Coated inside and out on downpipe for heat retention/shielding
3" Diameter Type 304 aircraft grade stainless steel
Type-25 Handling Kit
Thicker adjustable front and rear anti-roll bars
Anti-lift front sub frame modifications
Caster increase
Revised links
Type-25 AST suspension
12-way adjustable suspension for tailored damping
Revised damper settings
In-car adjusters
New designed AST springs utilizing the original rubber top mounts for improved NVH
Height adjustable
Powerstation Type-25 laser alignment
Braided Brake hoses
STI front lipspoiler
Reduces front lift by over 36% (MIRA proven)
Rubber lip extension
Individually numbered engine and dashboard plaques
Comprehensive warranty and after sales support
Performance figures:
415bhp @ 6,500rpm (over 400bhp available from 5,900-7,300rpm)
570Nm/420lbft @ 3,800 rpm (with over 300lbft available from 3,000rpm)
299bhp/ton
Spec C based weight 1385Kg (UK STI is 1,495Kg)
0-60mph in 3.8sec (estimate) 157mph (limited) Topspeed
cat amongst the pidgeons
Titanium Retainers
Dyno tested
Large Inlet
100 Cell Sports CAT
Caster increase
Revised links
In-car adjusters
Height adjustable
Braided Brake hoses
299bhp/ton
Originally Posted by dojj
theres no point in arguing about whats better now
its the scoobworth
its the scoobworth
Originally Posted by aduz
they just make the best better
I mean just look at what they did for the Sierra and escort, with out the cosworth engine they would still be nothing.
its the scoobworth
its the scoobworth
Seriously, that sounds the bollocks of the car, ive never seen it, driven it, heard fuck all but the spec, but the Scoobworth will be the absolute bollocks i reckon
I saw some of those components on the WRX forums here this week and thought there must have been a mistake. I knew they were involved with various manufacturers but Subaru was news to me.
Adam Graham
06-09-2015 07:04 AM
