XR4x4 calipers onto S1 will they fit?
Old 17-08-2006, 07:34 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Default XR4x4 calipers onto S1 will they fit?
Hi, just got hold of some XR4x4 calipers/carriers off an XR4x4 2.9.
Now what I would like to know is, will they fit onto my S1 rst?
If so, what carriers will I need and what discs?
And will my braded brake line fit onto the XR Caliper?
Ive been told the calipers are simmilar or the same as S2 calipers? and also been told I may need S2 carriers/discs?
Any help would be appreciated as hopefully fitting them at the weekend if it's possible!
Exscuse the phone pics!
Also Asked earlier in the escort turbo section but only had 1 person confirming i could fit them and would just like to know exactly what parts i need before I strip it down
Old 17-08-2006, 08:21 PM
vroooom ptssssh
It Wasnt Me!
cheers Matt, Sure thats what ive heard before also
Old 17-08-2006, 10:15 PM
vroooom ptssssh
It Wasnt Me!
Jus found these "rs turbo" brake calipers on egay for sale, looks like the same carriers?
Old 17-08-2006, 11:58 PM
SafeChav
SafeChav's Avatar
I'm not very up on all this single pot caliper business they all look the same to me
But im sure the 4x4 calipers are the same, and will go straight on with series 2 discs.
Old 18-08-2006, 12:07 AM
vroooom ptssssh
It Wasnt Me!
Snobby C*nt
Well their better than what I have, and are free, so they'll do for now, im told their just as good as 2wd cossie calipers if i used 2wd cossie discs and spacer brackets!?
Old 18-08-2006, 12:13 AM
SafeChav
SafeChav's Avatar
Snobby C*nt
No you knob!!!!
I meant i know fuck all about them, and even if i wanted to know about them they all look the same anyway i haven't got a fucking clue how you tell them apart
Old 18-08-2006, 12:27 AM
vroooom ptssssh
It Wasnt Me!
They differ on models of car, theirs a start
Old 18-08-2006, 12:38 AM
SafeChav
SafeChav's Avatar
Educate me oh great one
Old 18-08-2006, 05:07 AM
Wazzzer
Wazzzer's Avatar
S2s came with XR4x4 calipers so your ok with them
Old 18-08-2006, 06:07 AM
dojj
Resident Wrestling Legend
dojj's Avatar
the calipers are the same
the carriers are different due to the different offset on the S2 and xr discs
Old 18-08-2006, 01:00 PM
vroooom ptssssh
It Wasnt Me!
cheers lads, so im on the look out for S2 carriers/discs or S2 carriers/2wd discs and spacer brackets
Old 18-08-2006, 08:59 PM
dojj
dojj's Avatar
any sierra wih them discs will doo too
Old 18-08-2006, 09:52 PM
Thrush
Irritating c........
PassionFord Gold Member (Male)
Thrush's Avatar
As said, the calipers are identical, only the carriers are different. IIRC they fit the same 260mm (or is it 240, can't remember) discs the S2 runs....
To be honest, you're better off getting a pair of 2WD Cossie calipers and using them with 4WD discs (again it's too late for me so can't remember if it's the other way round) as they simply botl up with only a couple of penny washers needed as spacers
Old 18-08-2006, 10:11 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Why change to the same caliper
Old 18-08-2006, 10:16 PM
Thrush
Thrush's Avatar
S1's run a smaller caliper with a smaller pot and smaller discs The S2 disc upgrade is worthwhile, but in the long run it'd be better to go for the cossie discs n calipers
Old 18-08-2006, 10:18 PM
Charlie Chalk
Unknown.
THats what i thought , You can pick up a 2wd brake set-up quite cheap, can you not?
Edited as i cant spell
Old 19-08-2006, 12:50 PM
SafeChav
SafeChav's Avatar
it is the other way round
2wd discs and 4wd calipers, 2wd calipers are 4 pots
Old 19-08-2006, 05:08 PM
Thrush
Thrush's Avatar
Thats right - I always get that wrong
Old 19-08-2006, 05:20 PM
vroooom ptssssh
It Wasnt Me!
Im probably gonna get 2wd discs and spacer brackets and use the S2 calipers as ive been told they are just as good if not better than 2wd cossie calipers. . what truth is in tha it dont know! something about the S2 calipers having more surfice area coverage?
With the spacer bracket/2wd disc/s2 caliper setup, do I need S2 carriers or just the spacer bracket, caliper and disc?
Old 19-08-2006, 05:33 PM
stickertone
stickertone's Avatar
if you want to use the 4x4 callipers you need to use xr4i(not 4x4) discs, the pedel will be a bit spongey compared to before, but when they bite.. they really do, making heavy breaking in the wet interesting... hope this helps.. t
Old 19-08-2006, 06:21 PM
Thrush
Thrush's Avatar
S2 pads do have a 5% (~) extra surface area cover, but do not cover as much of the disc as the 4x4 Cossy pads, in terms of reaching the bell of the disc - the S2 pads come up short. That said, the majority of the braking force is to the outside of the disc anyway, so the pro's and con's will mostly come up even anyway.....
Old 19-08-2006, 07:30 PM
vroooom ptssssh
It Wasnt Me!
stickertone, Not sure what you mean mate, the XR4x4 calipers are the same as S2 calipers, so all i'd need is S2 discs and carriers or 2wd cossie discs and spacer brackets for that setup.
i'd assume the XR4i discs would be the same as s2 turbo items?
Thrush, I see what you mean. . hmm i'll prob stick with what I have seeing as they are free!
Anyone got S2 carriers/2wd discs for sale cheep? used discs are fine aslon as they aint fubar!
Old 20-08-2006, 06:00 AM
stickertone
when i did this conversion on my orion i ghia, i took discs and callipers off a 4x4 sierra, the discs hit the callipers when put on as the offset was wrong, so we put xr4i ones on and all was well
Old 20-08-2006, 08:51 AM
dojj
dojj's Avatar
the 2wd calipers are the best as they are 4 pots
the 4wd calipers are bigger versions of the S2 calipers (as found on the 90 spec onwards dohc sierras with discs all round)
the S2 caliper is a bigger version of the S1 caliper
the S1 caliper clamps onto a 240mm disc
the S2 caliper clamps onto a 260mm disc
the 4wd caliper clamps onto a 278mm disc
the 2wd caliper clamsp onto a 283mm disc
bigger is better but you can't bolt the 2wd caliper to the front of anything else without a bit of drilling and tapping of the hubs, but after that anything that fits onto a 2wd cosie brake upgrade wise will fit (so if you wanted to bolt on a 378mm conversion with ap 6 pots you could do so )
best of both worlds is the 4wd caliper and the 2wd disc, same bolt holes and, as thrush has commented, it's only the case of a washer to get the right disc to caliper offset sorted
Old 20-08-2006, 09:24 AM
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
i used xr4x4 calipers on my 89' xr3i, i'm sure i used rst discs, but could be wrong, they went on fine whatever though.
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
FlashRS
14-09-2015 12:36 PM
2wdsaph ben
17-08-2015 03:17 PM
track.focus'd
12-08-2015 05:53 PM
10-08-2015 12:08 PM
Quick Reply: XR4x4 calipers onto S1 will they fit?
