oil change
18-08-2004 | 05:13 PM
oil change
just done oil change on ma cossie,the oil presure has dropped fi 22lb to 20 ,it also sounds very tappety, is this the norm?
18-08-2004 | 05:14 PM
How long have you let it run for after the oil change?
18-08-2004 | 05:18 PM
Quote:
about 20 mins, then took it for a drive. it drives ok
18-08-2004 | 05:23 PM
It's still noisy? Even after the drive etc? Sure the oil levels ok? And did you use the right oil?
18-08-2004 | 05:25 PM
Oil level is ok,i used castrol rs 10/60 was told this was the best oil to use.
18-08-2004 | 05:30 PM
Did you use an engine flush?
18-08-2004 | 05:34 PM
nah,the oil that came out was fairly clean.
18-08-2004 | 05:35 PM
Thats strange then mate
& it wasnt noisy before the oil change?
18-08-2004 | 05:36 PM
Think it's supposed to be at least 35psi on tickover,somebody correct me if i'm wrong!
18-08-2004 | 05:37 PM
I wonder if you've used the wrong oil for the millage of the car?
18-08-2004 | 05:40 PM
its a 3dr done about 89 thou the guy a bought it of said the head gasket was done about 87thou
18-08-2004 | 05:41 PM
18-08-2004 | 05:44 PM
yeh their all the fookin same
18-08-2004 | 05:45 PM
18-08-2004 | 05:49 PM
oil pressure shouldnt be that low , what was it before you done the oil change??
18-08-2004 | 05:57 PM
Did you use a ford filter?? Not sure but would say that oil may be to thin
18-08-2004 | 05:59 PM
Quote:
1,8 bar ie 26psi on tickover with standard oil pump.
18-08-2004 | 06:01 PM
...at normal operating temperature....
18-08-2004 | 06:38 PM
mines 25 to 30 psi on idle when hot
18-08-2004 | 06:40 PM
18-08-2004 | 06:41 PM
Quote:
Mine is around 23-25 psi on idle when hot.
/Thomas Krath
18-08-2004 | 06:42 PM
impreza wrx sti version 8
18-08-2004 | 06:43 PM
use mobil 1 motorsport. 15w50.
thats what i use cos mine did the same wi the castrol.(rs)
Quote:
Originally Posted by Stu @ M Developments
what oil do you recomend?
whats other people using?
18-08-2004 | 06:44 PM
Mobile one Motorsport
18-08-2004 | 06:46 PM
cheers i'll give it a try
18-08-2004 | 06:53 PM
mine did the same on castrol, I cahged it for a different brand and it was fine again!
18-08-2004 | 07:46 PM
mines did the same as well, changed oil and sounded rattly as hell.
Think that the top end needs a while to fill its self properly with oil.
The tapping noise was gone in a couple of journeys
TPM961
15-01-2018 11:50 AM
dombanks
21-09-2015 09:38 PM
KennyWelsh
Ford Focus (All Models)
13-09-2015 09:28 PM
marky_g
12-09-2015 05:26 PM
Adam Graham
06-09-2015 07:04 AM
