dump valve not working?
Old Aug 18, 2004 | 10:01 AM
the madferrit's Avatar
the madferrit
Default dump valve not working?
I fitted a dump valve to my car about 6 months ago and it has worked fine until yesterday.what happens is, when on idle the boost sits at about 0.2 below 0 where it used to sit well below that. It still boosts fine but there is no sound from dump valve when I release or change gear now. Instead its gone back to the chatter I used to get. I had the valve off and it moves freely enough. It is leaking a little air tho when on tickover. I assume its not the dump valve coz surly it would still work when boosting and releasing. What should I check cheeRS
Old Aug 18, 2004 | 10:03 AM
Physio's Avatar
Physio
Have you checked the rubber seal inside?
Old Aug 18, 2004 | 10:04 AM
Rick's Avatar
Rick
is the boost gauge fitted into the same pipe where the dump valve vacume is?
Old Aug 18, 2004 | 10:15 AM
Jim Galbally's Avatar
Jim Galbally
have you checked all your hoses including the one on the top of the dumpvalve going to the plenum?
also is this an ERST or a cossie?
Old Aug 18, 2004 | 10:20 AM
DaveEscos's Avatar
DaveEscos
is it piston or diaphram?
if the latter then the diaphram has split
the madferrit
its acossie. havent relly checked anything except for taking it off and making sure it still moves which it does. It stpped for a while, then started working again and nows stopped again. I'l cheeck all the hoses but how do i ckeck the seal?by taking it apart?
Old Aug 18, 2004 | 10:30 AM
Physio's Avatar
Physio
Yep, just take that sucker apart dude!
Old Aug 18, 2004 | 10:33 AM
the madferrit
ok took it apart and theres a small split right on the rim. Is this my problem? i assume so. Can i buy just the seal? how much if i can?
Old Aug 18, 2004 | 10:37 AM
Physio's Avatar
Physio
BINGO! Get yourself a new seal they normally cost about £5 - £10 or dump the dump valve cos they really are
Old Aug 18, 2004 | 10:50 AM
the madferrit
now the problem is where do i get one from in wolverhampton. tried pj's but they got none. anyone olse round here likly to have them?
Old Aug 18, 2004 | 10:52 AM
Physio's Avatar
Physio
Im not sure about in Wolves, but if you give Hi-Tec a call on 01384 561777 speak to Tony & tell her i told you to call, she should be able to sort summat out for you. There in old hill near the merry hill centre.
Old Aug 18, 2004 | 10:55 AM
DaveEscos's Avatar
DaveEscos
Old Aug 18, 2004 | 11:11 AM
foreigneRS's Avatar
foreigneRS
Testing the future
get more than one while you're at it mate, this won't be the last time. shitty things.
Old Aug 18, 2004 | 11:23 AM
McPikie's Avatar
McPikie
Just ditch it, DV's suck more arse than the annual feltching convention
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
Red_bull
Aug 9, 2015 08:34 AM
