cosworth propshaft
Team HOTHOT!
If its rattleing, nip it up - get a pair of mole grips on it, jack a roadwheel up at the rear, and rotate the roadwheel anti-clockwise. this will tighten up the grease collar
Team HOTHOT!
just wind it right off untill it falls onto the splined part of the prop, pull the rubber bush back and apply grease round this area, slide rubber bush forward and then apply grease around it and inside the collar, then re-fit and tighten
thats the quick way, the long way is to remove the propshaft and grease everything
Adam Graham
06-09-2015 06:04 AM
