Computer reset
Old Aug 11, 2006 | 05:29 PM
White RS1600i's Avatar
White RS1600i
Default Computer reset
Need a lil bit of help. I bought a cheapy computer and collected it yesterday, all is well im using it now! lol but all my pictures ect when i send are coming up in the previous owners name
How do i make everything go into my name? he said he wiped it clean but obvously not!
CheeRS
Old Aug 11, 2006 | 06:17 PM
Frogford's Avatar
Frogford
best way is to format the harddrive and reinstall windows
Old Aug 11, 2006 | 06:21 PM
White RS1600i
waaaay over my head mate lol
im not to sharp with computers as you can tell, how would i do that?
Old Aug 11, 2006 | 09:54 PM
White RS1600i
Old Aug 11, 2006 | 10:09 PM
Thrush's Avatar
Thrush
Irritating c........
What exactly do you mean when you say "pictures I send are coming up in his name" ???
I'm guessing here that you mean the computer operating system is still set up with his name. If so this should be fairly easy. and I can show you how;
1) Click START on the tool bar and click on the picture at the top next to the name;
Then, you might get this screen;
If you do, just click the CANCEL button and you should see this screen;
Then click the CHANGE NAME (first option) and you should get this;
All you need to do is put your name in and you should be sorted
Old Aug 11, 2006 | 10:45 PM
White RS1600i
Cheers fella ive done that bit but its the name of who its registered to that buggin me as my names not 'abdul bawab' lmao
Old Aug 11, 2006 | 11:25 PM
collierm's Avatar
collierm
MP for K.I.S.S
Click Start Run, type regedit and click OK.
Click down through all the folders till you get to this location
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
There is an entry on the right hand side called RegisteredOwner. Double click it an put your name in. Click OK and close the registry editor. Now if you check the owner information, it should have your name there.
Matt
Old Aug 11, 2006 | 11:39 PM
White RS1600i
Cheers mate that bits worked
The only problem is say if i open my pictures it says in the tool bar
C:\Documents and settings\Abdul Bawab \My Docuements \My Pictures
Old Aug 12, 2006 | 07:32 AM
dojj's Avatar
dojj
Resident Wrestling Legend
open the location up as a folder (sorry, don't know how to explain that bit)
click up through the folders until you get to the one with his name on it
change the name from his to yours
sorted
Old Aug 12, 2006 | 07:53 AM
Adrian's Avatar
Adrian
Sounds like you need to create a user account for yourself.
Old Aug 12, 2006 | 08:03 AM
Eagle's Avatar
Eagle
Super Moderator
agreed
create your own user account ... transfer any files or pics you have to it .. then delete the abdul account
Old Aug 12, 2006 | 02:43 PM
White RS1600i
agreed
Cheers fellas yep that sounds like what im after, how do i go about doing it?
Thanks again
Old Aug 12, 2006 | 02:46 PM
Adrian's Avatar
Adrian
http://support.microsoft.com/default...279783&sd=tech
Should be enough.
Old Aug 12, 2006 | 02:59 PM
White RS1600i
Thanks guys, sorted! much appreciated
AJC
Oct 1, 2015 06:47 PM
Kam B
Sep 24, 2015 10:40 AM
fuzzy
Sep 4, 2015 10:11 PM
