Do ARP stud and nut kit use washers?????? (on cossie motor)
please say they dont
my kit never came with any, and as the nuts have like a built in washer i thought nothing of it, cus the old washers dont come off the bolts
and i even went to a local manufactures to get some but carnt get any in the size
ive now torqued the head all down so im going to leave it and see what happens
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Also does anyone know the torque without arp lube????????
well im gonna use the lube supplied with the kit so whats the torque setting for that??? and also do you use the lube to screw the studs into the block as well as on the nuts??
so do you just wind the studs into the block hand tight then torque the head down with the one torque setting.....as you have probably gathered, i havent read the instructions yet
There was a thread on here only a couple of months ago with a link to an ARP website that said IIRC that the nuts should be tightened and loosened 5 times (to wear off any burrs on the threads?) before final assembly. If you're fitting these in the near future it may be worth your while finding the thread and clarifying how these need to be tightened correctly.
jonfoc
16
11-09-2018 05:35 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
