Does anyone have the following Ford special tool.....
Team HOTHOT!
Does anyone have the special puller for removing the cambelt pully of the crank nose on a YB engine, without damaging the alloy cover?
If so, Please may I borrow it, I will pay postage for you, and a little something for your generosity
Paul
Paul
you mean the toothed pulley not the aux drive pulley?
if so it "shouldn't" need a puller it might just be stuck on the shaft give it some gentle taps and it should come off.
Mind you im sure I have read that some peeps have had to smash it off
mine have always come off no prob.
steve
steve
Team HOTHOT!
That is the pully steve - the small one for the cambelt that sits behind the main crank pully.
Never had it off my engine before, and I don't know if anyone else has neiher
I'm with Stu on this!!
Mine was seized solid - I drilled a small hole through the width of it top and bottom, then put the tip of my balljoint splitter in the hole and sheared the pulley into two pieces... Took about 5 mins, no way it was coming off without the proper tool, and could I fuck get one!!
It would have to be a very narrow puller to get in there - I filed my puller right down and it still wouldn't fit - there's little room between the cover and the pulley
Neil.
Neil.
borboyous
22-08-2015 11:17 AM
