bd14 cams reprofiled or bd14 cams from blanks whats the diff
what's the difference between re profiled bd14 cams and bd14 cams made from blanks i take it the both have the same v lift and duration or is it not
Stu @ M Developments
thank you .so are the valve lift the same on both re pro and blanks i dont understand how a cam would give the follwer a hard time both the std cam and bd14 valve lift are allmost the same only 8.5 is std i belive and 8.9 is the bd14 hope fully you can correct me on this
The cam gives the follower a hard time as it operates in a higher position than its design was intended for due to the metal removed from the base circle.
People seem to forget that the lift is the different between the front of the lob and the back, and that you can NOT increase the front height when you reprofile, so all you can do is remove from the back, this means the lifts have to be taller and hence are not working in the way they were designed to and it can shorten their lifespan accordingly, i would imagine that there is a greater sideloading on the valve guides as well potentially, its certainly the case on cars with rockers when the valve train geometry gets messed around with like this but i dont have enough experience of it on OHC engines to say if the same is true,
Stu, can you comment on that?
Originally Posted by Rick
cams
Is it SO bloody difficult to make one "exactly like it says on the tin"????!!
Mc5506
05-10-2015 09:57 PM
