Radiator water?
Radiator water?
I may be talking bollox here but has anyone ever heard of using antifreeze mixed with battery water ( deionised ) in their cooling system? Think that I read somewhere such as MCN that using battery water will make the water system run cooler and am looking for a cheap way to help temps on trackdays etc. Not currently a issue but every little helps
Originally Posted by KSA-Cossie
Isn't that stuff just a gimmick ?
The idea is very simple. Break down the surface tension of water to allow the heat to transfer better.
Have you washed your cooling system out first ???
If not and this was a technical bulletin from when I worked at a Scania agent and also beleive it went around a few car companys and Volvo truck and bus too.
Get ready for this !!!
DISH WASHER FLUID from your local supermarket !!!!
Mark RS
12-10-2015 06:01 AM
