Total seal rings
I used them in one of my cossies.
Mike Lowmand of Lowmand Jones Developments fitted mine.
Only thing is that they needed replaced after a couple of thousand miles
other than that they were fine.
Im not aware of a reason for them needing replacing sooner than normal rings, can someone explain to me why that might be the case.
I'm planning to use them for the first time in an engine im building for SBD16V off here for his astra but would be keen to hear as much as possible about them first as obviously its not my engine i'm experimenting with, although Rob will not be too fussed if he have to reblock and rering it after a few thousand miles anyway TBH if they wear bores out faster or something, but i cant see why they should?
I had them on my cosworth pistons in me old s2, were platinum brand ones i think, had no probs, after about 3000 miles the honeing marks on the bores were disaperaing
Bri.
Bri.
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
PS
The only reason i can think for more wear would be due to possibly exerting more force outwards onto the bore, but i cant see them doing that by much or it would start effecting performance too!
Football Cwazy
presumably it's blow-by your trying to eliminate Chip? is it that bad that you need to try these?
don't know that much about them though tbh, how do you know they are the right size for the piston? presumably there's no gap to measure when fitted to the bore?
enlighten me
enlighten me
enlighten me
enlighten me
You can still size them with an appropriate "end gap" on the main portion of the ring.
Its to try and maintain a better leakdown result for longer that i wish to use them as nitrous engines have massive cylinder pressures and can "eat" the ends of the rings and increase the gap fairly quickly.
my mate ran them on his tomcat turbo engine which was pushing 258bhp
as far as im aware the car is still going strong now, never had any problems what so ever
got them off a local engineering company who recommeneded them only cost 100 quid which i didnt think was a bad price
they use them in there v12 race jag engines and have no worries
Football Cwazy
yeah i can imagine what nitrous does!!!
what block material is the LET? are the rings compatible in that respect? do they even come in different grades or materials?
can only see premature wear being due to incorrect sizes,or wrong materials
07-10-2015 12:56 PM
deathrider666
28-09-2015 06:12 PM
