torque
Old Aug 2, 2006 | 09:33 AM
THE RADMAN's Avatar
THE RADMAN
Default torque
what is it, or what are the factors that determine whether your car makes good torque over actual bhp? ie you can have 2 more or less identical chipped cars,using same chips,injectors etc,but one of them will produce far more torque than the other,why is this?
Old Aug 2, 2006 | 09:37 AM
Bullett's Avatar
Bullett
think it is detemined by what components are used,eg turbo,pistons etc.but not sure how you go about finding out whats got to matched to to high torque.maybe compression ratio to?
Torque is how hard the crank gets turned.
BHP is how hard it gets turned multiplied by how quickly.
Hope that helps.
Old Aug 2, 2006 | 09:38 AM
Default Re: torque
PS
No you cant, unless there is a fault they will be the same torque and the same power if t hey are the same spec.
Old Aug 2, 2006 | 09:57 AM
THE RADMAN's Avatar
THE RADMAN
interesting
Old Aug 2, 2006 | 10:15 AM
AlexF's Avatar
AlexF
bhp is a formula that give you POWER (rate of work).
Torque is what makes you accelerate REGARDLESS of engine or road speed!
Alex
Old Aug 2, 2006 | 10:16 AM
reality's Avatar
reality
Torque is the force and power is the rate at which you can apply the force.. in an ideal world, "identical" specs will provide idential results.. however rolling roads are bullshit, engines are rarely the same spec (owners rarely know what the actual spec, history is).. it's all academic really!
Old Aug 2, 2006 | 10:18 AM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: torque
In the scenario you suggest the main difference is usually engine wear such as bores/cams.
If turbos, you will normally find one has more boost PEAK than the other.
Camshaft TIMING of course also plays a part in the peak torque area.
Old Aug 2, 2006 | 10:28 AM
Porkie's Avatar
Porkie
Boooooooooooooooost!
Old Aug 2, 2006 | 10:34 AM
AlexF's Avatar
AlexF
says the man with a NA car in his siggi
Old Aug 2, 2006 | 10:36 AM
Bullett's Avatar
Bullett
but he has had plenty with plent of boost.
Old Aug 2, 2006 | 10:45 AM
AlexF's Avatar
AlexF
so true
Old Aug 2, 2006 | 10:52 AM
Bullett's Avatar
Bullett
J871yhk
id struggle to afford just the engine mods in one of his cars let alone the whole thing
is that your mini in sig?whats in it?
Old Aug 2, 2006 | 10:59 AM
AlexF's Avatar
AlexF
J871yhk
Its BOOOOOOSTED
170 bhp A-series turbo
www.afracing.com/mini.htm
Old Aug 2, 2006 | 11:00 AM
Bullett's Avatar
Bullett
J871yhk
cool whats it weigh?
Old Aug 2, 2006 | 11:05 AM
AlexF's Avatar
AlexF
erm that one is proably 650kg
My racer is about 500-550 and this year should be pushing 200 bhp
Alex
Old Aug 2, 2006 | 11:13 AM
Bullett's Avatar
Bullett
wow not bad 261bhp per tonne!
and 400bhp per tonne on racer!!
proper little bruisers then!
Nov 1, 2015 06:53 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
