diffferance between dump and blow off valve
It Wasnt Me!
I think the HKS super sequential (SSQV) is a twin piston type! never heard of one being used on an rst tho!
IMO dont run one at all, they end up causing problems eventually and are pretty pointless!
You can get the bailey in both recirc and non recirc. Both can be used on the rst(in terms of effecting idle) although not too relavant seen as your ditching the metering head.
A dump valve and BOV are the exact same thing. Both can come in atmospheric or re-circulating versions. Not something you want to run unless you have to.
Re: diffferance between dump and blow off valve
Originally Posted by stevenebm
awrite folks.whats the differance in the above.saw a hks blow off dump valve and it looked pretty cool.can these be used in rs turbos and the like.cheers
andy
DEYTUKURJERBS
Yup, as per Stu.
Just the yanks/japs have used the name for summat its not really.
Tho some people call them pop off valves.
And somepeople call BOVs/DVs wastegates, so its a bit of a minefield if you dont know what you looking at!
SMILER258
28-09-2015 09:04 AM
