coil over set up
any advise on setting a set of gaz coil over up on a 4x4 saff would be great
, ie ride height!
How do i tell how much ive lowered it by now? ive fitted 18s as well so mesurments are out the window!!
Got a bit of driveshaft wobble on thisafternoon ,and as far as i can see the shaft is straighter than before so should be better! may try the xr4x4 shaft again tomorow cos when i tryed it last time it was to long and caused undrivable judder round corners.
the way i done it was to put the coilovers to max height
car on ground level and get a tape measure and see how much it is from arch to top of tyre
then id lower the car to that measurment
xr4x4 driveshaft shouldnt cause you judders going round croners, ive ran them for years and never had a problem
DixieTheKid
11
06-06-2020 11:20 AM
