YB 2WD Thermostat Housing Questions.
Hi Guys,
The above has two small outlets (approx 6.00mm) on the left hand side.
I presume one is for the turbo feed and one the air bleed back to the header tank – Is that correct ?
If so which connects to the turbo as one is engine side of the thermostat and the over is radiator side ?
Thanks for any replies.
WD
WD
Thanks,
So to confirm - The turbo is fed from the front outlet i.e. the radiator side of the stat and the engine side of the stat is blanked ?
Cheers,
WD
Cheers,
WD
DavidK
27-09-2015 02:55 PM
