name that boost hose!!
the S shaped one is metering head to turbo, the L shaped one is turbo to cooler, the far right one is the rad hose, long one that goes from top left to right is the thermo housing to header tank...
if you can get a pic of them spaced out with numbers it might be better for people to give you the right places for them![Top](https://passionford.com/forum/images/smilies/smile011.gif)
looks like you're missing a boost hose though
Its Broken.....
Originally Posted by Rs1
That kit looks a bit crap
Your much better off getting on the phone to Roose motorsport imo![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Its Broken.....
Originally Posted by Christian and Beccy
The far right hose is the crankcase to rocker cover breather for a CVH and I would imagine that the one next to it is the other side of the rocker cover.
![](https://img.photobucket.com/albums/0703/Roosemotorsport/Hoses.jpg)
These are the only ones that i recognise.
No1: Rocker cover to sump S1, S2, FRST, Fiesta cvh.
No2: Oil modine to cylinder head 2&4WD cosworths
No3: Y connector to air temp switch on inlet manifold S2. Also 2&4WD cosworth heater matrix to steel pipe running through exhaust manifold.
No4: Oil modine to cylinder head T25 Esc cosworth. also RS500 steel pipe under exhaust manifold to water pump.
No5: Oil modine to cylinder head S2
No6: Turbo oil return to sump S1
No7: Turbo to intercooler S1
No8: Crossover pipe to throttlebody S1, S2
No9 Metering unit to turbo S1, S2
I would send those all back and get my coin back.
Regards Paul.
Its Broken.....
Regards Paul.
Originally Posted by xr4x4rs
dont think no.7 is for a rst
dont they have an extra bend in them as the compressor side is facing down as that just has one angle like a cosy air filter pipe
no.1 is definitly the crankcase breather
Here is my full hose kit for the S1
![](https://img.photobucket.com/albums/0703/Roosemotorsport/EscortRSTurboS1boost.jpg)
![](https://img.photobucket.com/albums/0703/Roosemotorsport/EscortRSTurboS1coolant.jpg)
![](https://img.photobucket.com/albums/0703/Roosemotorsport/EscortRSTurboS1ancillary.jpg)
Regards Paul
Originally Posted by seriesoneboy
the bore of no1 is 32mm ish...( iirc) and breather hose is 22mm..
Breather hose will be 19mm.
![Content](https://passionford.com/forum/images/smilies/content.gif)
Regards Paul.
Russ Payne
25-09-2015 08:29 PM
