Are these Spark plugs a bargain?????
Please can someone let me know because if they are im going to buy a set!!!
Cheers,
Mark
http://cgi.ebay.co.uk/WRC-CHAMPION-S...QQcmdZViewItem
Cheers,
Mark
the descrition is very contradicting
so they are good for a standard / stage 1 cossie ..
but need different for stage 3+
so .. make your own mimd up im sticking with my 071's from ford
these were made specifically for the Cosworth WRC programme. They are a cool grade plug designed to withstand massive combustion temperatures and compression. The WRC engine ran 50 psi boost
These plugs are ideally suited to any engine with a long reach type plug, running between 200 - 300 bhp.
if you have a Cosworth running more than 300 bhp, dont worry. I have a few sets of RC505 plugs that are a grade hotter that will suit your engine
The 071 work so well that i dont bother with fancy plugs anymore for mine, i used to run it on 90 quid a set iridiums but i just dont bother anymore.
I see no point in looking into other options when you can get a set of plugs for 6 quid or whatever that work perfectly.
what do you set the 071's to on a escos stage 3 approx 350 bhp? i know they should be gapped wid the feelers at a angle, remember seeing the pic on here. whats the metric and imperial gap setting, thanks
Sean.
Sean.
deathrider666
28-09-2015 06:12 PM
