2wd gear sticks???
PF Idiot Sniper
yes its a common problem mate. i had it in my 2nd cossie. just get it welded up and it'll be fine. i highly recommend cutting out the bit that i guessed was to dampen the vibrations. its maybe an inch long and thicker than the stick. this gives you a feel like a short shift and it is far more positive IMO! cut it out and weld it up. sorted!
nooooooooooo
never shorten a 2wd cossie gear lever!!!
you can knacker the syncro's!!!!
i could change gear faster than they could on my old cossie..and that was with a standard lever!!
You will have to weld it as they are not available from Fords anymore, I was lucky when mine snapped posted it up on passionford and Martin Hadland had one going spare which I brought
right welding it today then.. stronger the better.. lucky i was near home so just stayed in 3rd.. the only gear i could get in using the stump.. do people normally use these quick shift things. mine has one but im thinking maybe it was better without it.. ?
The Youth.
30-09-2015 09:59 PM
SMILER258
28-09-2015 09:04 AM
DavidK
27-09-2015 02:55 PM
