Scrapyard Hybrid Turbo?
I need to find / construct a turbo with a fairly hard to find spec. Not bothered if garrett or IHI etc.
I need a small exhaust housing / turbine wheel either from a 1200-1400cc engine or one of a pair on twice the capacity.
I then need to match this to a compressor wheel/housing that will support 200 bhp.
I was thinking of maybe a T2 from a renault 5GTT with a larger cold side from something else or maybe a Fiat uno IHI unit with something similar.
Any ideas??
Many thanks,
Doug.
Any ideas??
Many thanks,
Doug.
Take a T2 turbo from the 5GTT and fit the compressor side of a Peugeot 605, 406, or citroen evasion, XM 2.0 petrol turbo engine.
Goes straight on.
Put them togehter and you've got a turbo that can supply about 220 bhp
Tried it on my Peugeot 106 gti turbo and worked fine.
Goes straight on.
Goes straight on.
Goes straight on.
How much bhp does your 106 make? Sounds like a good project! Any probs with the wet liners moving around?
Why do you want to do this? Take a standard erst turbo. The 0.36 exhaust housing is already too small to let you get to 200bhp.. the compressor is about right for 200bhp but the t3 0.36 is just too small.. I mean, you can force it... but then you're seriously compromised
The exhaust housing may be too small for the 1600cc s of an ERST but the engine i want this turbo for is much smaller!
The ERST hot side would be far to large for what i need.
Originally Posted by Rick
the 0.36 will do 200hp with ease - in fact it's the front wheel that is more on it's knees...
Here's the compressor map..
As for the first question, why not just use a straight out of the box Rover 200/800 turbo, T25, 0.49 exhaust housing with the largest off the shelf comp wheel, good for about 220bhp.
On a R5 they make full boost around 3500rpm. The other option is to fit this comp wheel to a standard T2 turbo.
How about a couple of GT2559VNTs? Ive got 5 in stock...
Even if you don't use the full use of the VNT mech, you could fix it to the desired turbine a/r.
T28 compressor wheel, and T25 inlet flange.. Will need external wastegates tho..
No problems what so ever with the liners.
Friend of mine has got the same engine with a T3/T4 on it, has got 290 bhp (on the dyno) and no problems there either.
Ok to clarify..... the turbo is for a 1000cc bike engine so thats why i need the tiny turbine wheel/housing!
It may only be 1000cc, but it revs to nearly triple a car engine, so if its too small will heavily restrict it...
Dyno development for that bike went:
Stock 112 bhp
1800 nissan turbo 130bhp. (it hardly spooled up)
After trying three other turbo combos with progressivly smaller turbine wheels/housings we got 180 bhp @ 10 psi
The smaller engine just doesn't have the energy/flow in the exhaust to spin anything with a big turbine housing up.
Yes, but the Nissan housing is a large 0.64 housing.
My point is don't go for a tiny (as in T2) housing and wheel..
The Rover unit would be a good happy medium.
It's certainly not black and white when it comes to picking an exhaust housing.. Most people will just try them all and observe the back pressure until they get the best for their package..
It was actually of a silvia and was a .48 from memory.
The VNTS I have would be a good option, at least you can play around with the mech and fix it anywhere between a 0,64a/r and a 0.2 a/r.
DEYTUKURJERBS
The 60 trim (standard nissan 200 turbo) has a pretty tiny exhaust housing (which strangles a 1.8 to 200bhp), so maybe for your application it'd work better..
Good for 250bhp at 16psi on the S13.
And the S14 has a much bigger T28 good for nigh on 300bhp.
JK12
33
26-04-2021 12:09 PM
