Ive killed my Mondeo engine, but whats happened?
DEYTUKURJERBS
Going down M5, about 90mph, strange screeching noise appeared, not loud, dbit like a screeching belt, or something rubbing a bit, seemed quite minor, changed in note with throttle position more than revs.
After a few secs car started losing power, first i thought it was the aircon as it lost power in the same way, but then kept losing power.
No knocking or rattling or nowt you could hear.
Water temp was fine, oil pressure light wasnt on.
Looked in rear view mirror and thought i could see dispersing blue (ie oil) smoke, but not sure.
Car kept losing power and slowing, got another mile till it got to sub 30mph, so pulled up and car immediatley stalled, no oil light once, till it stopped.
Popped bonnet n steam/smoke was coming from head, seemed more like smoke, and certainly smelt like burning oil.
Head was super mega hot, littlest touch gave me a blister. Finally got oil cap off and head seemed dry.
Checked oil on dipstick and was at maximum, as ever.
Water was pretty much fine too.
Head was that hot it was still too hot to touch 2 hours later.
Turning engine over sounds fine, but seems easy, so maybe no compression either.
So whats up? Its not lost oil, there no mega rattles or knocks and the oil light didnt come on, so would that be dead oil pump?
But if wasnt that, why would head be dry?
Engines totally fucked tho I guess
Spose best find a s/h one to put in. Easy engine swap?
It Wasnt Me!
hmm, im thinking maybe blocked oil way(s) to head?
if their was no oil pressure in the bottom end the oil light would come on, unless it's fucked? so oil pump sounds ok, screeching noise maybe cams cos they were dry?
at a guess
at a guess
DEYTUKURJERBS
at a guess
at a guess
Steve, I would suspect that the aux drive belt has snapped or glazed over badly.
This grooved poly-V belt drives the power steering pump and water pump, and either of those could have siezed initially causing the screeching noise. If you had low power steering fluid, or a sudden loss of all the power steering fluid it may well cause the problem described.
Remove the top part of the black plastic cambelt cover to check the aux drive belt.
DEYTUKURJERBS
I checked the belts you can just about see without taking the covers off, and they all intact still, but others, dunno yet.
Originally Posted by Stavros
...............How would that have caused the oil problem etc etc? Esp as it didnt really have a water problem?
Three jobs for you tomorrow:
1. Check the power steering fluid level.
2. Do a full leak down test.
3. Post up more pics of Hanna.
DEYTUKURJERBS
True.
And ive totally ruined it with Hannah anyhow, I dont remember what I said as was out on the smash and under the influence, but the text reply said...
"fuck you. A- im not a slag. B- dont take the piss out of me, my ex, or where i live. im not in the mood steve. fuck you."
Last ive heard from her
True.
"fuck you. A- im not a slag. B- dont take the piss out of me, my ex, or where i live. im not in the mood Steve. fuck you."
Baby Cheesus
the water pumps on the mondeo 2.0L's are prone to failure. they are plastic impellors and shear off, resulting in 1 cooked head and blown H/G between cyl 2 and 3
for it to screech tho, somehing has seased or cam has got jammed
my old cabby, the screw that hold the metal plate behind the cams came loose and jammed the zorst cam sproket
didnt make a noise but cut out and the cunt was turning over real easy as it had bent all 16 valves
scuse my typeing,, im pissed again
DEYTUKURJERBS
Its a 1.8, and didnt overheat the water it seems.
Oh fuck knows, spose we will find out when we pull the engine out, and YES, i need for help dan
You have to really abuse a zetec to kill it...
Any zetec with sub-200k miles which sounds good will be ok.
Look for clean-ish oil and a recent filter too.
Post up the results when you find out why it lunched itself!!
DEYTUKURJERBS
But then again it has full ford service history.
Does deffo seem in my head that it was an oilway blockage to the head, as for the last week the top end has been a bit rattly, and never has before.
steve mine dont this the other night same speed with the air con on 1.8 r reg done the h/g but it went bad hope this helps mines going again now but the head is fooked glad it went in part x for a 522 plate focus
It Wasnt Me!
at a guess
at a guess
Not sure tbh, has it been serviced at all?
What oil problem?!?!?!
DEYTUKURJERBS
The head was bone dry in there, no oil in the head, and so hot it went a bit black and was still too hot to touch 2 hours later.
Water only very slightly boiled over after I stopped the engine.
So thats an oil prob, innit?
Well there shouldnt be much oil in the head...
Did you hear the tappets die? Without oil pressure there is no valve adjustment!!!
Not sure theres a problem with the oil at all...
At a couple of hundred degrees C the head should be too hot to touch and in this weather will take hours to cool off!
Alex
Alex
DEYTUKURJERBS
Head stinks like burnt oil too, and is remarkably clean.
No taps or rattles at all really, but a really wierd squeaky noise for 20secs before it died.
Turns over really fast now, so obv no compression.
Hey mate sorry to hear bout ur engine probs But just to let u know i have a full engine from a mondy... 2.0l 16v complete engine and gearbox still atatched, ecu and air flow meter. Head was reconed less than 100 miles ago! it was in my mates mondy and he lost control driving like a dick, spun and stacked the rear end into a telegraph pole !! so i whipped everything under the bonnet . let me kno if u r interested mate. im in bedfordshire tho....
Cheers Dave
Cheers Dave
DEYTUKURJERBS
lickshot- could be intereted for the right money, got the ECU?
fudge- itd make some dodgy noises n died straight away surely? the car slowly lost power, drove a good coupla miles while car lost power.
ill maybe have a look on the weekend if i got owt else to do.
