52 plate 106 service light!
if it's the same as the 306 hold the trip clock reset button down while ignition is off turn ignition on and off a couple of times and it starts to do a count down on the display just choose your interval .. good luck..
On the 206 (should be the same as that), you hold down the trip clock reset button and turn on the ignition and then there should be a countdown, once it has reached zero, turn it off then it's done!
Thanks
Dan
Thanks
Dan
