Fitting Green Induction Kit
Old Jul 13, 2006 | 10:36 AM
Zetech's Avatar
Zetech
Default Fitting Green Induction Kit
Hello,
I've just come over from www.ffoc.co.uk through recommendation of other members and thought I might just give you peeps a shout regarding fitting a Green cone to my 1.8 Zetec.
I bought it off ebay and it comes with the oil breath pipe cone, however this does not fit straight onto the cylinder head outlet so I decided to use the pipe that used to run to the bottom of the airbox, with it dangling down near where the airbox used to be.
However, since I have put it all together, and although the sound is amazing, when I change gear, mainly in 4th, the engine idles a lot more and kicks out loads of black smoke.
Is there something I am doing wrong that I'm missing or do you recommend resetting the ECU?
Chris
p.s nice site
Old Jul 13, 2006 | 10:52 AM
D19 STE's Avatar
D19 STE
You can either put your oil breather pipe into the bottom of your filter like the K&N design or get one of those breather filters with the right end from maybe halfords
And yes reset your ECU
Old Jul 13, 2006 | 11:05 AM
Zetech's Avatar
Zetech
Cheers matey,
Will resetting the ECU sort out the black smoke then?
I never had that trouble when I put one on my Rover though
p.s how do I reset the ECU
Eagle's Avatar
Eagle
Super Moderator
hello and welcome to the site
Old Jul 13, 2006 | 11:07 AM
Zetech's Avatar
Zetech
Thanks Eagle
Old Jul 13, 2006 | 11:14 AM
D19 STE's Avatar
D19 STE
Originally Posted by Zetech
Cheers matey,
TBH not too sure why you are just getting the black smoke to reset your ecu disconnect your battery ideally over night, then re connect it, just make sure you know your stereo code
If you still get the black smoke put your standard filter box back on to check to see if you still get the smoke
Old Jul 13, 2006 | 11:18 AM
Zetech's Avatar
Zetech
Thanks,
I've put the standard box and filter back on and it's fine
Doesn't black smoke mean it's not getting enough air?
I left the air flow meter on the main pipe etc so maybe that's getting confused
Oct 9, 2015 07:38 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
