changing engine mounts on a fourbie ????
Old Jul 11, 2006 | 08:44 PM
slowpoke's Avatar
slowpoke
Default changing engine mounts on a fourbie ????
how hard is this to do ?
any specialist equipment needed at all ?
anyone got a like step by step guide to doing it ?
matt
Old Jul 11, 2006 | 08:51 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Matt - I told you how to do it today the easy way
Support engine using a jack with a block of wood, unbolt the 19mm nuts on the alloy arms holding the rubber mounts, unbolt the alloy arms off the engine (4 bolts per side) and then swap the mounts.
the passenger side is a bit difficult as you have to either remove, or adjust the position of the oil cooler
Old Jul 11, 2006 | 08:53 PM
Graceland's Avatar
Graceland
Team HOTHOT!
OR just bring the fucker to me on monday and i'll do it for you
Old Jul 11, 2006 | 08:56 PM
dave cos4x4's Avatar
dave cos4x4
Bit akward Matt.
remember doing mine ages ago, right pain.
BUT....
got told to take the bolt out of the mount and put it in place and then put the bolt back in.
Old Jul 11, 2006 | 08:57 PM
dave cos4x4
thats if it the uprated mounts you have Matt.
Old Jul 11, 2006 | 09:04 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Dave - They are a piece of piss to do, Managed to rattle it down to 15 mins a side
Old Jul 11, 2006 | 09:05 PM
Eagle's Avatar
Eagle
Super Moderator
very easy ..
loosen the subframe bolts .. support engine on trolly jack via sump.. lift engine .. insert new mounts .. lower engine .. refit subframe... passenger side is a pain due to the boost hose or you can fit em from underneath
Old Jul 11, 2006 | 09:09 PM
dave cos4x4
the length of thread fooked me up,could not lift the engine high enough.
but, like i said, the uprated mounts have a bolt through them,take out ,slide the mount in, put bot in.
may not even have to lift the engine much.
Old Jul 11, 2006 | 09:10 PM
Graceland's Avatar
Graceland
Team HOTHOT!
damn you all have some weird ways of doing it
Old Jul 11, 2006 | 09:13 PM
dave cos4x4
OURS is weird!
easier.
Old Jul 11, 2006 | 09:18 PM
Eagle's Avatar
Eagle
Super Moderator
my way was easier .. use a big bar to lever one side up at a time if there is not enough room
Red_bull
Aug 25, 2015 06:27 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
