going on track on sat car now boils over..... help!!!!!!!
Today I finished of months of work building my xr4x4 track car then as I was putting it away it boiled over, did some checks and it seemed to be an airlock, the rad was changed months ago but the car hasn't run much since just around my workshop.
put the heater on hot it was warm, the temp was in the middle, turned it off removed the thermostat as I thought it could be that, topped it up then and ran it again it got to normal temp then boiled up (by boiled up I mean the pressure increased in the header tank and overflowed it the water isn't too hot!)
so we then put the front of the car on my 4 poster and raised the front as high as we dare ran the engine and it was fine....
than as soon as we lowered it it overflowed again!!!
our thinking is that it is a blocked heater but im not sure how that would cause the pressure increase
we also did a pressure test on the cooling system( using the correct equimpent) and all was fine
compressioin tested a couple of cylinders and they were ok (couldn't do the rest as the comp tester fouled the manifold!)
so I am on track on saturday now with no car
any one any ideas???
thinking of bypassing the heater tomoz and trying that, cant get my head round why it only does it on level ground tho...
sorry for the essay but im gutted 6 months of work is about to go to waste..
cheers
steve
cheers
steve
If you have hot air in the car wont be the heater matrix blocked
Try another expansion bottle cap as the 16psi pressure relief valve may be faulty thus allowing coolant to escape .
Hope that is of some use ?
Regards Doug .
Regards Doug .
Originally Posted by the youth
doug, with the coolent level at minimium and the cap off at tickover the level gradually increase till it's coming out the top, the system isn't under pressure as the caps off..
cheers for the idea tho,
Steve
Steve
If the cap reads 12psi or lest on test its fooked bin it !
Or if you have another ford there borrow the cap to rule it out .
Regards Doug .
Steve
Steve
Regards Doug .
Brian,the rad temps are hot all over it, no cold spots,
gladdy and chris were helping me out and reckon it's the heater , im not convinced tho..
steve
For what its worth and its gonna cost feck all nick it of the mondeo mate only gonna take 20 mins of your time and hey no dirty hands yayyyy lol
Best of luck mate
Regards Doug .
Best of luck mate
Regards Doug .
I genuinely feel gutted and drained that after 6 months of hard work the car has let me down with less than 48 hours to go!!!
hope I can find a fix tomoz..
regards,
Steve
regards,
Steve
bad news mate looks like we have all leftt it a bit late
These cars should have been finished ages ago ,and croft is only round the corner
Mine is running a lot better ,so i will give it a couple of laps to see how it is ,if it aint sounding to good (missing and the like)i will be bringing it off and spending some time so it is good for latter events
saph in dorset
14-08-2015 10:10 AM
track.focus'd
12-08-2015 05:53 PM
Versus_Creations
24
05-08-2015 09:32 PM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
