best place to get a cossie oil pump?
does anyone make a better one than another?is it worth putting a high pressure one in?
seem to remember a problem with some new pumps that were faulty from somewhere?
my oil pressure once fully warmed up is only 15psi on idle-45psi at 2000 rpm and 55 at 3000 rpm.bit low?
just get one direct from cosworth I believe they have improved the design to the original ones, or failing that Woodford garage also sell the genuine ones, which is where I got mine from. A cheaper option would be grahame goode but these pumps come without a cover and you have to use your old one, something I didn't want to do.
Hope this helps
Hope this helps
big_Rad
15-09-2017 09:36 AM
