when buffing cars......
There mainly used for compounding, I wouldnt use it tbh.
Ideal if your paint is "flat" ie no shine. If thats the case get some compound ie farcela g10 or g3 and apply that with the buffer, but keep the area you are buffing moist with a mist of water.
Then take that of with a decent cloth then apply polish by hand and remove with another decent cloth and then follow that up with a decent wax, then you should have a nice and shiny car
Just watch the edges, if its a new mop head it sometimes has a mind of its own and it dont take much to burn through, as i have found out a few times at work
Originally Posted by JoeE30
Some times buffers "burn" the paint of not kept moist...
Be careful
Be careful
Be careful
Be careful
G3 DEFO needs to be used with water, and plenty of it. It needs the water for the abeasives to break down properly, and u need a bit of heat in the pannel.
Rotary is fine, if your using a sofr foam head, and a light polish - much better than by hand.
Be careful
Be careful
when i worked at a body shop for citron didnt use water and polished 30+ cars a day! just the way i was shown, may be wrong but i never had any problems
A lot of bodyshops get it really wrong. I bet they told u to use the side of the buffer/hold it at an angle?
If you use it dry, it will remove flat marks, but will leave marks of it's own due to the abrasive's not breaking down. New soft paint isn't as likely to mark as old paint though.
Polished Bliss
Concours d'élégance.
04-05-2009 03:56 PM
Polished Bliss
04-05-2009 02:37 PM
