Problems with bd14 cams
Old Jun 20, 2006 | 02:17 PM
sygjim's Avatar
sygjim
Default Problems with bd14 cams
a friend has a small problem....
he had bought bd14 cams and on the inlet cam, there is a groove but not the same as standard .
on the exhaust side, there is no groove !!!!!!
Do you have an idea how to fit the vernier pulley on it ???
I suppose that he need to machine it.
If somebody has an idea .....
Old Jun 20, 2006 | 02:20 PM
Stu @ M Developments's Avatar
PassionFords Creator
Sorry, i dont understand what your asking.
What groove? Do you mean on teh bearing? If so, that is correct, but what has it to do with your verniers?
Unless you mean the woodruff keyway?
Old Jun 20, 2006 | 02:32 PM
sygjim's Avatar
sygjim
i don't know the word in english
it's a machined line on the cam which permit to fit the pulley on it with a little piece to sold it . it's the keyway ?
Old Jun 20, 2006 | 02:45 PM
Ah yes, its called a KEYWAY and the item that fits into it is called a WOODRUFF KEY.
I personally would send the cam back if it arrived without one, even though technically it does not need one.
Old Jun 20, 2006 | 02:56 PM
sygjim's Avatar
sygjim
thanks for the english course
but there is no timing cams problem if there is no KEYWAY ???
Old Jun 21, 2006 | 07:12 AM
sygjim's Avatar
sygjim
up
Old Jun 21, 2006 | 10:04 AM
Sorry? If you arew asking what i think your asking, then no there is not.
118 degrees with a 360degree wheel and DTI dial is 118 degrees.
Old Jun 21, 2006 | 10:16 AM
sygjim's Avatar
sygjim
thanks stu
my friend will try to contact the vendor to correct this
cos elle
Sep 25, 2015 09:52 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
