803's/3-bar and stg 3 chip on a cossie
i wanna put the stg3 set up on my cossie being the dark greens,3-bar and stg 3 chip but dont wanna just put them on then go give it sum down the road.Is there anything else i need to check or adjust i.e the fueling etc to make it safe without blowing anything up.
fit it all up, then drive gently to tuner. Nothing you can do yourself really, apart from check condition of sensors/connectors/loom etc - esp fuel pump
You can make sure all the small bore boost & vacuum pipes are secure, as well as the main turbo/intercooler/throttle boost pipes are also in good condition, and jubille clips tightened correctly.
Ensure you have the correct grade of spark plug for your conversion. You may also need a new wastegate actuator, and for what they cost, a new dizzy cap, rotor arm probably wouldn't go amiss.
Then as said, off to someone who can set it all up safely, and check fuelling, sensors working correctly etc.
Then once done, treat it with some respect, and safely get used to your new level of power and then enjoy it
If in any doubt, let a pro do it all, it's worth it for peace of mind.
cheers peeps,looks like i wont put the gear on untill i arrange for it to be set up-dont wanna take any chances cant afford a blown engine right now
