dropping nuts into engines
it wasn't me it wa a garage I went to which I won't name right now but they tried to get it with a magnetic rod, couldn't and gave up!
would it block the oil from going around?
my oil light isn't on!
if it were my car i would tell them its there fucking job to remove it!
if ya engine goes bang are they gunna pay for it.....
tell them to drop the sump and remove it, its there problem not yours
Resident Wrestling Legend
who's going to remove the sump? hope it's the garage
i collected a running engine (obviously it wasn't running when i picked it up, i would never have been able to catch the fooker
) but someone had taken the plugs and coil packs off of the top
not a problem i thought, went to spin it round and it couldn't go
eventually, after a few days, i thought "fook it" and took it to bits
one of the bolts from the coil packs was stuck in the piston
seing as i needed to take the head off anyway as i had to do the head gasket, this wasn't as bad as it could have been, but i've got to pull the sump off now (with counterbalance shafts etc) to get the piston changed
if your engine is running with some sort of foriegn object in it, it's not going to last long when that object decides it's going to egt moving in the oil system
I would of refused to take the car back until the garage had sorted it.
As said already, its the garage's problem. Not yours![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Are you driving it around ?
get back down there, give them the spill that ya talked to trading standards if they kick up.
if you remove the sump, that sump gasket, oil, oil filter really you have to pay for then your time and haslle for there mistake.
sorry to say mate but your be a fool if you let them get away with this.
only good thing is they told ya about it but dont make it any better.
name and shame!
name and shame!
Originally Posted by Hrsturbo
yeah been driving it as I thouht he garage wouldn't have let me go if it wasn't ok to maybe sit in the sump!!
get it back down there lad
i wouldnt touch it well in saying that seeing as they done it in the first place i dunno if i would want to take iot back there but it is there fault and they have to sort it.
it wont get sucked into the oil pump so worse case it will sit in the sump, fact is its not ment to be there anyway.
what were they doing to drop it in there anyway?
call them, explain the situation, tell them you have been advised NOT to use the car due to this problem
explain to them that you need the car for your everyday life and the sooner they can remove the nut the sooner you can use the vehicle
also explain to them you need them to come and collect it and return it (note the mileage on the trip as well as the odometer down AND how much fuel you have in it before it goes away)
if you go there all hollerin and shouting you might get a different response than if you call them and tell them what has happened and suggest they rectify the problem
if they fob you off call the citezens advise and see what they asy, worst case is you go to court to recover the costs, but thats a LONG LONG way down the road
any decent garage will sort it out and bollock the guy who dropped the nut in there in the first palce and it all ends happily ever after
adjusting my solid flowers which have now started ratteling again! it was a nut off the rocker arm
so for what little it cost and i would of though Ł30 for hours labor tops its now gunna cost ya oil, oil filter and a sump gasket thats, what Ł20 for gasket, Ł5-Ł10 for filter Ł20 plus for oil then ya time.... mate come on, take it back and get them to fix there error
it was Ł50 an hour and was there 7 hours but charged me for 3 cause of messing around and they did it twice and it rattledand third time was ok!
what the fuck
they charged ya Ł150 to adjust lifters and throw a nut down the oil way
bet ya walking funny now mate
i wouldnt even be replying on here as i would be stood waiting for my sump to be put back on but THEM by now
and a refund for the trouble
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
"just a thought, if you can drop the sump etc why couldnt ya adjust the lifters?"
I did but wanted it done properly as it was my first time fitting cam ect
ah right, bet ya wish ya had done now.
if ya dont trust/want them to do it and sort it out i would at lease ask for my money back and do it my self, that way it covers cost of bits ya gunna need, and ya only gotta hope the sump gasket dont leak after
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
Originally Posted by GUZZLER
i seen plenty of cvh's get a collet dropped down the oilway when people have been doing stem seals, most of them got left in the sump
never seen 1 cause a problem!
Football Cwazy
JoeyBoyden
04-01-2024 02:36 PM
lockie
31-07-2015 10:03 PM
