Engine running issues - non Ford!
Old Jun 13, 2006 | 01:52 PM
RichardPON's Avatar
RichardPON
Default Engine running issues - non Ford!
Considering there are a fair few techincally minded types on here, and most MR2 owners don't know what is what with an engine, I though I'd post here and try and get a response.
Basically, my car (MR2 turbo) has the followuing symptoms:
Running rich, mental fuel consumption, intermittent missing on boost, poor running from cold, very high idle when cold and warm.
Does this sound like a vacuum leak?
The early 3S-GTE use an AFM, and as standard have a re-circ dv. Mine has a VTA dump valve - this has always been a bone of contention with MR2 afficianados, as obviously any dumped air is not metered. Could this be the cause of my poor running?
Also seems to accelerate so much better on partial throttle, but at WOT it causes all manner of missing etc.....
Any techincal type thoughts would be appreciated, and don't do the whole "this is a Ford forum" thing. At least I'm asking about cars and not what colour sweater I should knit for my pet hamster....
Old Jun 13, 2006 | 02:03 PM
rsnissan's Avatar
rsnissan
sounds like the AFM itself.........................does it run a hotwire?
Stavros's Avatar
Stavros
DEYTUKURJERBS
Air leak somewhere post AFM giving it fucked readings (or fucked AFM, but leaks more likely).
Sounds like every Skyline and SX etc etc with same problem.
Boost pipe split or similar, could even be a lil vac hose thats split.
Or a blowing inlet manifold gasket.
Or leaking DV.
Old Jun 13, 2006 | 02:59 PM
Do you know anyone with an AFM you could swap on to test?
Failing that, some sort of air leak, either the pipework or the DV sounds possible.
When you say its running rich, how do you know that?
What circumstances is it rich under and by how much?
Old Jun 13, 2006 | 03:00 PM
Ps
I think that a natural colour along the lines of beige would be best as he will be too easy for cats to spot if you go for red or similar.
Old Jun 13, 2006 | 03:15 PM
Gregs's Avatar
Gregs
Ps
could try tiger stripes!
Old Jun 13, 2006 | 03:18 PM
Rab's Avatar
Rab
Fucking superstar........
Mate, thats definately a leak. When I rebuilt the one I ahd it was the same thing. I ended up binning the dump valve and plugging both ends
Old Jun 13, 2006 | 03:34 PM
Scrap it Pon
Old Jun 13, 2006 | 05:09 PM
RichardPON's Avatar
RichardPON
Cheers guys!
I've found some online multimeter pin out type testing stuff on the net to check voltage outputs etc so will give that a go to check the signal to the ECU, and also the AFM itself.
I know it's running rich by the fact that most of them do, you can smell the unburnt fuel - that is to say I know it's running rich some of the time..... I've not put any AFR equipment on it, although I do have an EGT gauge, but I think the sensor's packed up.
Phil - I could turn it into a 355 replica and it'd still be better than your shonky hair chested 348
Old Jun 13, 2006 | 05:31 PM
Billabong's Avatar
Billabong
Slightly off at a tangent, what air filter are you running?
Old Jun 13, 2006 | 05:35 PM
..one that filters air? QUACK
SteveB's Avatar
SteveB
Richard I had a similar sympton with a R34 GTR and simply sprayed brake cleaner thru the AFM (took it off the car) to clean the hot wire and it solved the problem....
Old Jun 13, 2006 | 05:38 PM
aduz's Avatar
aduz
and you were asking me if i was on the correct forum u goon
Old Jun 13, 2006 | 05:40 PM
Billabong's Avatar
Billabong
Reason I asked, is because AFM's hotwire doesn't like filter oils QUACK
Old Jun 13, 2006 | 05:53 PM
Cheers guys!
Dont forget that unburnt fuel could be due to an ignition problem, could be something as simple as the plugs need replacing.
Old Jun 13, 2006 | 05:55 PM
rsnissan's Avatar
rsnissan
indeed that was to be my line of enquiry........
Old Jun 13, 2006 | 05:58 PM
Billabong's Avatar
Billabong
Thought it might when you mentioned the 'hotwire'
Old Jun 13, 2006 | 07:47 PM
RichardPON's Avatar
RichardPON
Done the plugs..........
I know scoobies didn't respond to some of those "oiled" filters....... and fooked up the AFM..
The Filter is an HKS job, but it is widely accepted as being the poniest filter on the market.....
Old Jun 13, 2006 | 07:49 PM
Billabong's Avatar
Billabong
But is it an oiled type, Rich?
Old Jun 13, 2006 | 08:18 PM
RichardPON's Avatar
RichardPON
I don't think so Bill, but with closer inspection, there isn't much filter left!
TommysKeeper
13
Aug 14, 2015 08:22 PM
Zoggon
Aug 10, 2015 10:39 AM
yawiejon
15
Aug 9, 2015 06:36 PM
Red_bull
Aug 9, 2015 08:34 AM
