Boost Question
Old Jun 12, 2006 | 07:20 AM
Tony Ryan's Avatar
Tony Ryan
Default Boost Question
A pal of mine has a T34 .48 fitted to a std 2wd engine with a -31 actuator , the car doesn't make much boost even if you heavily preload the actuator arm , its running an amal valve currently .
Im wondering why , ive read a bit about jetting these to increase held boost , is this the next step or should he dump the amal valve and connect the compressor to the wastegate to control boost , hes looking for 1.4-1.6 bar on greens . ???
Old Jun 12, 2006 | 07:26 AM
GARETH T's Avatar
GARETH T
are you sure the actuator is a -31,, and strong enough?
Old Jun 12, 2006 | 07:29 AM
Tony Ryan's Avatar
Tony Ryan
Hi Gareth and happy birthday for tomorrw , lol .
The actuator has the std -31 numbers marked on it , it was very hot yesterday tho and it felt like a normal -31 to pull on .
Old Jun 12, 2006 | 07:31 AM
GARETH T's Avatar
GARETH T
what boost was you seeing?
Old Jun 12, 2006 | 07:34 AM
Tony Ryan's Avatar
Tony Ryan
He tells me 10 psi , we wound on a load more turns but it made little or no difference , its a racecar so he didn't watch the gauge all the time but reckoned it peaked at 10psi , didn't seem quick either .
Old Jun 12, 2006 | 07:43 AM
GARETH T's Avatar
GARETH T
i would change the actuator and if that dont work have a look at the exhaust housing
Old Jun 12, 2006 | 07:49 AM
B16's Avatar
B16
I am running the same spec as your friend, I have a small restrictor in one of the amal valve tubes not sure which one though. It was fitted by Mark Shead of M A Developements. Withouit it I was not pulling much boost.
Old Jun 12, 2006 | 08:01 AM
Graceland's Avatar
Graceland
Team HOTHOT!
make sure your throttle butterfly is opening fully aswell - get a friend to press the accelerator all the way down and then have a look and see if the throttle is open fully. Had this problem on my car, tried new pedals, cables, throttle bodies, couldn;'t work out for the life in me why it wouldn't open fully.
Then I realised that someone had placed a throttle stop under the carpet
The DIVA's Avatar
The DIVA
Tony.....
Remove the return restrictor completely from the Amal valve(pipe stub is marked "R")and then set-up the actuator until you have about half to three quarters of a hole of of pull,this should give you what you are after.....
Old Jun 12, 2006 | 08:40 AM
Tony Ryan's Avatar
Tony Ryan
Cheers for the replies , bit confused tho as one says to add a restrictor and another to remove one . Wouldn't it be better all round to remove the amal valve and use the acuator preload to control bleed , sorry ive very little experience with these ?
Old Jun 12, 2006 | 09:00 AM
GARETH T's Avatar
GARETH T
Tony Ryan
you wont get enough boost from a -31 with the compressor piped too the actuator,,, unless you use a bleed valve
Old Jun 12, 2006 | 09:13 AM
Alvyn's Avatar
Alvyn
that set up SHOULD be able to make loads more boost than 10 are you sure there's not got a boost leak ie i/c knackered.
Old Jun 12, 2006 | 09:14 AM
Stu @ M Developments's Avatar
PassionFords Creator
Tony, back the preload off to about 6mm and then remove the restrictor from the "R" port and see what happens from there.
Old Jun 12, 2006 | 06:40 PM
Tony Ryan's Avatar
Tony Ryan
Thanks Guys, i'll try all these different ideas but i reckon Gareths about on the button with the -31 being too weak for the turbo .
Many thanks Stu , we'll have a mess with the amal but its coming off anyway , i cant trust that it will do its job under these conditions and a twin port maybe on its way .
Old Jun 12, 2006 | 06:46 PM
Dont be too hasty with your cash. With std jetting you wont get much boost from a -31 on any turbo. Its only an 8psi spring.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
