MOT madness
Old 09-06-2006, 05:53 PM
evander
evander's Avatar
Default MOT madness
Ive just had the S2 RS in for an MOT and its failed, Ive still to pick it up so I havnt realy spoke to the station yet but the long and short of it is. It failed because it has no ABS. The complete ABS system has been removed leaving just the driveshafts, the tester says that its all computerised now and it tells them on a list what to check for and ABS is listed for my car. Ive never heard of anyone esle having this problem. What about everyone that removes the rear compensators and fits a bias valve, it would fail for this aswell? Has anyone else came accross this problem? This is realy p*****g me off, I dont want to have to fit that crap back on the car. I dont have it anymore anyway, it was launched in the skip months ago.
Old 09-06-2006, 05:56 PM
Steve200+
Steve200+'s Avatar
My car had malfunctioning ABS when it went through late last year... Don't get that.
Old 09-06-2006, 05:57 PM
dojj
Resident Wrestling Legend
dojj's Avatar
does the light light up on the dash?
yes?
remove it
sorted
Rab
Fucking superstar........
Rab's Avatar
Go somewhere else..... Remind them it's the non ABS version of the Escort RS Turbo
Old 09-06-2006, 05:58 PM
89xr2
Brap!
89xr2's Avatar
Because it's all changed now. Lots of new regs brought in. Each MOT has to take 45 minutes or more as well. So prices have gone up as you have to log the car onto the computer and it has to stay logged on for 45 minutes so testers cant do anywhere near as many in a day.
Old 09-06-2006, 06:03 PM
adamS2RST
adamS2RST's Avatar
Hmmm...mine was ok with the ABS removed, I still have the light in the dash which works when the handbrake is applied. This was before the new MOT system was running in my local garage though, so looks like next year will be fun
Old 09-06-2006, 06:10 PM
evander
evander's Avatar
Doii the light has been removed, The only bits left from the ABS are the 2 driveshafts.
Rab I tried that one but the tester said all 89 RST's had ABS and showed me the test sheet with the listing. He also went on to say its highlighted so must be fitted then went on to agree with me that the ABS is a pile of crap. Did all 89 RST's come with ABS??
Old 09-06-2006, 06:11 PM
Matt Baxter
Back in black!
Matt Baxter's Avatar
yeah the new system will tell if a car has abs as standard .
its a pain in the arse for us the testers aswell .
but if the abs has been removed completely I would pass it.
just tell the tester that its never had abs as that will put doubt in his mind
and he will have to pass and advise
Old 09-06-2006, 06:12 PM
Moose 130
Moose 130's Avatar
I had this when testing a car for a customer last month. Bands were missing but the ligt still worked as per the description.
The manual states thet -
Missing components
Where a vehicle is presented for test with an ABS component obviously missing but, follows the correct sequence of operation, the defect must be brought to the attention of the presenter.
If your light goes on and off with the hand brake then ask him what the manual says about it.
if you have no light and no ABS I'm sure it should fail as it's std fitment and the light does not work.
it's important that your light works as it should regardless of wether you have abs still fitted.
Stupid VOSA rule, but it's the way out of your trouble.
Old 09-06-2006, 06:14 PM
rssteve
rssteve's Avatar
would go somewhere else TBH. if it aint fitted how can it be faulty. Try ringing the dvla if not and see what the score is with it. I no one of the frs boys put his cat back on for mot time, and the computer didn't tell him to do the emmision test so he couldn't fail it even if it had the decat on
Old 09-06-2006, 06:18 PM
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
but the mot rules state if its fitted it has to work,if its not fitted it doesnt have to work because its not there so it carnt,this is an mot not type approvel (sp) .
how can a.b.s be tested dureing an mot anyway?
Old 09-06-2006, 06:20 PM
Moose 130
Moose 130's Avatar
The point is it should be there as std on all erst's as the vts device has that info from Ford.
What it says is that the light should be there and work as Ford designed it.
The fact parts are missing is not a failure.
JUST IF THE LIGHT DOES NOT WORK AS FORD INTENDED
If the tester deliberatlty ignores a failure point he could loose his licence, so it's your problem not his.
Just fix the damn light and stop moaning
Old 09-06-2006, 06:22 PM
adamS2RST
adamS2RST's Avatar
Missing components
I should be ok then
shane
shane's Avatar
i hope i dont have to refit that ABS shite I know loadsa people who have removed the ABS and aint had no trouble though!But im not sure if they've had an MOT after the rule change!
Old 09-06-2006, 06:23 PM
dannyblackpool
Boost Builder
dannyblackpool's Avatar
what if you strip car to use for track days and have no rear seat or belts, will it fail on seatbelts?
DUDE_SWEET_FRST
DUDE_SWEET_FRST's Avatar
ive removed the abs from mine aswell
Old 09-06-2006, 06:28 PM
89xr2
Brap!
89xr2's Avatar
Not as far as I understand it. If the car has no back seats then if there are seatbelts in there still the belts are disregarded as there is no seats. But if you have seats you have to have belts. That's the way I read it anyway when checking out to build my stripped xr2
Old 09-06-2006, 06:29 PM
evander
evander's Avatar
Moose I actually removed the bulb from the dash but Ill get the light working as it should again, Ive been on to one of my mates and he says to take it to him. So well see what happens
Old 09-06-2006, 06:45 PM
Moose 130
Moose 130's Avatar
just put the bulb back in and wire it to the hand brake light.
job done.
Old 09-06-2006, 06:53 PM
Matt Baxter
Back in black!
job done.
but the abs light must go in the right sequence to pass I would wire it to the oil light if it was me
Old 09-06-2006, 08:23 PM
Moose 130
Moose 130's Avatar
job done.
not with an Escosrt, they come on with the handbrake.
Old 09-06-2006, 08:36 PM
teamfatboy
Frog Tosser
teamfatboy's Avatar
mine failed on just the abs light on the dash not working
Old 09-06-2006, 08:42 PM
Guinnless
Guinnless's Avatar
job done.
Ignition light would be best.
Old 09-06-2006, 08:51 PM
Moose 130
Moose 130's Avatar
job done.
the vts device says it comes on with the handbrake, anything else would fail.
Old 09-06-2006, 08:59 PM
DUDE_SWEET_FRST
what about in a fiesta rst? does it come on with the handbrake aswell?
how do you wire it to come on / of with the handbrake
Old 09-06-2006, 09:36 PM
adamS2RST
adamS2RST's Avatar
As Moose say's it should come on when the handbrake is applied
Old 09-06-2006, 09:38 PM
The Sludge
garibaldi
The Sludge's Avatar
strange one that evander mate
I have abs still, but none of me belts fitted on it, but it passed
Old 10-06-2006, 10:49 AM
Oranoco
Oranoco's Avatar
My S2 has the ABS binned off and no back seat and a roll cage. The MOT guy uses the new system and mine failed.
Fortunately it failed on a duff headlight and a back brake. Teh ABS and lack of seats was no problem at all
Old 10-06-2006, 11:08 AM
Rick
Rick's Avatar
mine went through NP on new style.
Old 10-06-2006, 11:32 AM
adamS2RST
adamS2RST's Avatar
Old 10-06-2006, 12:07 PM
Wazzzer
Wazzzer's Avatar
same here, mine went straight through with the ABS removed and no dash light...
I thought it was optional on ERSTs? (same as the fiestas)
strange that the light should be on for MOT purposes if the ABS isn't there, surely that can be seen as trying to blag it even more?
Old 10-06-2006, 12:47 PM
Snowy_Astra
Snowy_Astra's Avatar
Ahhhhh the beauty of starting with a stock shell thanks god i did!
Old 10-06-2006, 03:24 PM
cos jon
cos jon's Avatar
Mine passed MOT with ABS fitted but not connected - didn't fail on that.
Old 10-06-2006, 03:33 PM
mark_24v_wiring
mark_24v_wiring's Avatar
So where do you stand with a modded car then If you have removed the abs system coz its total shite that makes the car modded and therfore should not be subject to the same mot requirements??????????????
It seams to me that the new mot is open to real abuse by the testers themselfs as my local garage would pass the car so long as the brakes worked ie in balance you cant even test abs correctly at a garage any way all you can do is make sure the light goes on and off like its supposed to which as we all know means nothing at all.
Old 10-06-2006, 05:04 PM
evander
evander's Avatar
It looks like Ive just been realy unlucky putting it into this garage and in my case the fail is apart from the light entirely down to the testers own interpretation of the rules. I did try to blag it and say it never had ABS and the garage owner started going on about risking his testing licence so Ł45 down the pan.
Old 10-06-2006, 05:41 PM
AndyRST
AndyRST's Avatar
Basicaly your car has failed the brake test because the ABS light fails to light up on the dash. There no way the tester can tell if the ABS is working on the rolling road that they use for braking testing becuase all there are looking for is the braking force against the rollers, not if the ABS is pulsing.
My RST had the ABS removed properly and the ABS light working when ign on and handbrake on and it never failed an MOT for ABS not working
Adam, your S2 will be fine through a MOT, they will see its mint and well looked after
Old 10-06-2006, 05:59 PM
zippyobrien
zippyobrien's Avatar
aww, fuck, that means im gunna have to sort mine out
Old 10-06-2006, 07:51 PM
mark_24v_wiring
You can always appeal to the about it and complain that as the abs is no longer fitted to the car at all how can it be a failure the car is modded and therfore will not be at the std manufacture specs there must be a way of doing this
Old 10-06-2006, 09:54 PM
dojj
dojj's Avatar
i removed the abs from the 3 door when i fitted the bias pedal box
the tester said he was going to fail it because the abs wouldn't work
i pointed out to him that there was no abs (bias box plus remote servo's caused lots of complications at that time ) because i had removed it and he was fine about it because i'd explained it to him
if he'd just carried on and i hadn't noticed him asking his mate he wold have failed me first and then possibly made me cough up for another test later on
this is going back well into history as it was 1993 when this happened
Old 10-06-2006, 11:52 PM
adamS2RST
adamS2RST's Avatar
lol Cheers Andy - They didn't spend too long looking at it last time
Quick Reply: MOT madness
