whats the difference between 2k and cellulose paint?
as above is there any difference, and what will go over rattle tin primer the easiest, many thanx in advance
any cheap places on line where i can buy cheap 2k paint?
got quoted Ł80 from a paint shop, for 1L ford diamond white, 1L thinner, 1L hardener
thought that was a bit expensive
DUDE_SWEET_FRST
a litre down my way is Ł12.00 plus vat so yeah i would say that is expensive
whats the difference though
5 ltrs of 2k diamond white + 2.5 ltrs hardener
so how much hardner would i need then is there a ratio or summat.
can anyone answer my original question, whats the difference between cellulose and 2k?
cheers mark
cheers mark
Celly is air drying, 2pack dries via a chemical reaction (ie using the hardner)
2k is dangerous shit, legally you arent allowed to use it, inless you operate a sealed booth which filters paint fumes before venting to atmosphere... Which I doubt you have as you would know the difference if you did
HTH
HTH
2k paint
u will need 2 parts paint to 1 part hardener then a splash of 2k thinners!
i take it uve got all the compressor and spray guns then?
to spray 2k paint u will need the necessary respirator as the paint contains isocyanate which will damage your lungs severley!!!
rsguy
44
29-09-2015 03:29 PM
SMILER258
28-09-2015 09:04 AM
