Cossie Phase sensor .. how reliable are they?
Old 10-08-2004 | 11:50 AM
DaveEscos's Avatar
DaveEscos
Default Cossie Phase sensor .. how reliable are they?
just wondering of most people on here have replced theirs? are they that prone to malfunction?
also how do you gap it correctly?
is it just a case of keeping the screws loose then tightening once the sensor strip is a few mm from the rotor arm stump?
cheers
Old 10-08-2004 | 11:57 AM
GARETH T's Avatar
GARETH T
try a little closer than a few mm's
i think they are quite reliable really, no moving parts for them to fuck up only the wire
Old 10-08-2004 | 11:58 AM
Disabled Account's Avatar
Disabled Account
Dave,
I might be wrong on this but if yours is a T34 Es Cos then it does NOT have a phase sensor!
AFAIK the phase sensor is fitted to Small Turbo Es Cosie (Fakes ) only, they replace the conventional distributer and are VERY reliable!
Old 10-08-2004 | 12:00 PM
whitneyd's Avatar
whitneyd
What is the gap measurment then??
Karl's Avatar
Karl
Norris Motorsport
Usually very reliable apart for aging burnt out wires as Gareth has mentioned, gap using a feeler gauge to 10 thou. Always worth replacing if your's has'nt been replaced since car was new.
Old 10-08-2004 | 12:01 PM
DaveEscos's Avatar
DaveEscos
Doug, it is a T34 Esc cos
and it does have a phase sensor inside the dizzy
one of these
Cheers Karl
Old 10-08-2004 | 12:02 PM
Disabled Account
Opooops,
Edited to say "it shows how little I know"
BTW what is the thing in a Small Turbo Escort Cossie that replaces the distributer called???? I honestely thought it was known as a phase sensor
Old 10-08-2004 | 12:04 PM
Karl's Avatar
Karl
Norris Motorsport
Doug you've gone mad.
All cosworths EXCEPT small turbo escos use a phase sensor inside the distributor.
Old 10-08-2004 | 12:05 PM
DaveEscos's Avatar
DaveEscos
doug!
mine DOES have one!
you are going mad!
Old 10-08-2004 | 12:08 PM
Disabled Account
Opooops,
Old 10-08-2004 | 12:25 PM
GARETH T's Avatar
GARETH T
Doug Stirling, its called the phase sensor on a small turbo, its just not built into a dizzy
Old 10-08-2004 | 12:26 PM
gurnE's Avatar
gurnE
Replaced crank and phase sensor on mine pretty much as soon as I got it.
Gap for phase sensor in new money is between 0.2 and 0.3mm
Old 10-08-2004 | 04:10 PM
Disabled Account
Gareth, thanks for clearing that up............I knew that small turbo Es Cossies had a phase sensor.....I just did'nt know that other Cossies had one fitted in the dizzie.........So I'm only going half mad
Old 10-08-2004 | 04:14 PM
whitneyd's Avatar
whitneyd
What is the gap supposed to be on the crank sensor for a small turbo? Is it adjustable?
Old 10-08-2004 | 04:15 PM
gurnE's Avatar
gurnE
From memory 0.6 to 1mm
I'm sure someone will be able to confirm
Old 10-08-2004 | 06:16 PM
Damo V's Avatar
Damo V
Clearances
TDC sensor to pulley teeth.............. 0.6 to 1.0 mm
Dizzy cam to phase sensor..............0.2 to 0.3mm
Old 10-08-2004 | 07:10 PM
Stoo's Avatar
Stoo
How much are these new?
Indyrs
04-12-2022 01:39 PM
DixieTheKid
11
06-06-2020 12:20 PM
IainRS1700T
25-09-2015 07:44 AM
gcfcos
24
21-09-2015 05:26 PM
wheelwizardrefurbs
18-09-2015 09:59 PM
Quick Reply: Cossie Phase sensor .. how reliable are they?
