Sponsored by:
Sponsored by:
tips to remove seized sump plug...
Old 04-06-2006, 03:41 PM
dannyblackpool
Boost Builder
dannyblackpool's Avatar
Default tips to remove seized sump plug...
td escort oil needs changing as its more like treacle now than oil, but sump plug is seized solid and rounded to fuck, obviously thats why oil is so manky as obviosly previos owner had a mare trying to remove, best way to remove without fooking sump please peeps
Old 04-06-2006, 03:44 PM
Replica
Replica's Avatar
weld another nut to it
jaimesdna
jaimesdna's Avatar
hammer & chisel. if its really stubbern heat it up first with a blow torch
Old 04-06-2006, 03:52 PM
Muzz
Muzz's Avatar
Tried a rounded off socket?
Took most of my engine apart with those
Old 04-06-2006, 03:58 PM
gurnE
gurnE's Avatar
Alloy sump? If so and it's that tight the thread is probably already fucked
Old 04-06-2006, 04:02 PM
dannyblackpool
Boost Builder
yup ally sump thats why dont want to force it as dont want to be changing the sump after ripping out threads, did think of welding a nut on but dont think ill risk the hammer and chisel
Old 04-06-2006, 04:06 PM
dave cos4x4
dave cos4x4's Avatar
hammer a smaller socket over it.
works sometimes.
Old 04-06-2006, 04:08 PM
dannyblackpool
Boost Builder
you dont understand how bad the plug is lol looks like they have rounded on a 13mm, tried a alf inch and made worse,filled a flat and tried open end and made even worse! ill try that 1st i think then weld a nut on if no joy
Old 04-06-2006, 04:15 PM
turbo.jon
turbo.jon's Avatar
had same bloody problem with mine tried hammer chissel and i fooked it up well bad so then bought second hand sump off ebay that turned up and nut was fooked too so it still aint had oil change yet the bloody thing as cant be arsed to fit new sump or even try get the nut off the spare sump
Old 04-06-2006, 04:18 PM
dave cos4x4
tae the oil filter off and crank it over a few turns,soon get the oil out.
Old 04-06-2006, 04:24 PM
dannyblackpool
Boost Builder
already thought that lol but wont get the sludge out
Old 04-06-2006, 04:31 PM
Old 04-06-2006, 04:36 PM
James
James's Avatar
lol, just what i was gonna say!
welding a nut on is best, or file it down and hammer on a six sided 12mm socket.
Old 04-06-2006, 05:17 PM
gurnE
gurnE's Avatar
I've got a pair of these:
If you can get on the bung square there's nothing they won't grip. The teeth are angled so they really bite into the metal.
I got mine from my local snap-on dealer but they are water pipe pliers made by Knipex so you can get them from lots of home diy type shops (£5 cheaper without the little gold Snap-on logo on the handle too )
Old 04-06-2006, 05:49 PM
TrevCos
TrevCos's Avatar
You can get sockets that grip the flat sides rather than the corners of the nut. Halfords will sort you out mate.
rsguy
44
29-09-2015 03:29 PM
youngben
27-09-2015 09:37 PM
Quick Reply: tips to remove seized sump plug...
