SECS monitor alarm limits
I fitted a second hand SECS to my escos and it was running but went out today and getting a few alarms, flashing up for Map input and for water high temp. Car is driving with no probs and temp gauge is normal. I was wondering if the limits for the alarm had been set lower by the previous owner. Its showing a peak of 24psi map and water temp max of 102.
You can set these to whatever limits you want for boost and i assume water injection, if you need the SECS instructions PM me your e-mail address and i'll send them. Cheers
Originally Posted by R4N S S
that map input fault is a case of too much boost as I dont think the SECS monitors can read more than 2bar boost.
It just converts the 0-5V signal to the ECU into PSI
If you're running over 2 bar on a 3 bar sensor, then your ECU is blind to the extra air
Neil.
SMILER258
28-09-2015 09:04 AM
