OIL LIGHT STAYING ON
Old 29-05-2006 | 11:45 AM
BAZ S1's Avatar
BAZ S1
Default OIL LIGHT STAYING ON
STARTED MY 4X4 COS THE OTHER DAY AND THE OIL LIGHT STAYED ON TURNED IT OFF AGAIN STRAIGHT AWAY, ANY THOUGHTS ?
Old 29-05-2006 | 11:47 AM
xr4x4rs's Avatar
xr4x4rs
have u checked the level of oil
also check the wire hasnt come off the switch and replace the switch
if this doesnt cure then could be more serious
Old 29-05-2006 | 11:52 AM
BAZ S1's Avatar
BAZ S1
YEA OIL LEVEL FINE ,WHERE IS THE SWITCH MATE?
Old 29-05-2006 | 11:54 AM
xr4x4rs's Avatar
xr4x4rs
under neath the inlet manifold at the back
its behind the oil filter
Old 29-05-2006 | 11:57 AM
BAZ S1's Avatar
BAZ S1
CHEERS MATE WILL LOOK AT THAT SEE IF ITS THE PROB OR NOT IS THE SWITCH DIFFERENT TO THE OTHER PINTOS OR DO I HAVE TO GET ONE FOR THE COSSY ESPECIALLY
Old 29-05-2006 | 11:59 AM
xr4x4rs's Avatar
xr4x4rs
proberbly the same bu unsure
for the sake of £5 its worth just getting a new one fro the car
any local parts suppliers should have them
Old 29-05-2006 | 01:25 PM
DazC's Avatar
DazC
Rounded off oil pump drive is a likely candidate. Sump off job but that means it would probably be easier to take the engine out, and if you go that far, you might as well give the engine a freshed up.
hopper350
04-09-2015 12:53 AM
CrOwSoN15
14
03-09-2015 12:21 PM
turbowag
03-09-2015 08:07 AM
StephTell
02-09-2015 06:31 PM
Quick Reply: OIL LIGHT STAYING ON
