quick tech question, wheres my Fan switch ? (esc tdi)
just picked up a T reg Escort 1.9 Tdi bloody fans not cutting in.
Someone tell me where the fan switch is please.
cant see one in the rad?
there is a switch on the thermostat housing a small 2 pin doesn't look like a fan switch but when bridged it does nothing think it may be a temp sender.
Right, this can get complex. The Escort diesels had fan switches in about 3 different locations depending on it's spec (air con greatly complicates things). It's either in the thermostat housing, top radiator hose or the bottom passenger side corner of the rad.
Some are blue 2 pin switches, others are red with 4 terminals for 2 stage fans like the Escort Cossie.
right found another escort same as mine when you unplug the fan switch (on thermostat housing) the fan comes on automaticly mine does not ive checked with it unpluged and theres no power at the fan either could be a relay problem but not sure what relay ?
anyone with any ideas?
I think the one in the T/stat housing is the temp sensor for the aircon. By disconnecting it, you might have triggered the aircon cooling fan. I think the fan switch is actually in the top hose if it's got air con.
It's a long time ago since I last worked on an Escort diesel with air con so iam jsut trying to remember bits about them.
yeah, thats where it is on non air con models for sure, the relay is behind the battery, i'm pretty sure one of the fuses in the little block on the frfont of the battery is also for the fan and/or a 30amp in the main fusebox.
