valve springs help
Old 28-05-2006, 08:45 AM
Hrsturbo
Hrsturbo's Avatar
Default valve springs help
can I change them without taking the head off or will they fall through the block?
Old 28-05-2006, 09:00 AM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Can be changed with the head on. Turn the engine over so that the cylinder you are working on is on TDC to be safe.
The stem seals normally stop the valves dropping through.
Take care not to drop a collet though!!
Old 28-05-2006, 09:06 AM
Hrsturbo
Hrsturbo's Avatar
ok cheers I give it a go now then as I already have it set at tdc
Old 28-05-2006, 09:10 AM
Alvyn
Alvyn's Avatar
take the spark plug out and fill the space left in the cylinder by using a ball of string as another way of stopping valve dropping!
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
SMILER258
28-09-2015 09:04 AM
RS-Rikki
21-09-2015 07:27 AM
Quick Reply: valve springs help
