Want a fully mappable ECU for £260????
After writing an article on Megasquirt in Fast Ford I had loads of phone calls asking if i could sell supply people with ready built units. I couldn't do this and i was struggling to recommend someone reliable that could, until now.
Phil Ringwood wrote most of the code for the comonly used extra version of MS so has vast amounts of experience with MS. He has now started up his own ready built MS supply service. His units come with every thing you would need - software, serial lead, map sensor, short loom etc. He is based in Norwich and will post to UK and EU.
http://www.extraefi.co.uk
I've just just had another V3 ECU of Phil with nitrous control, switchable maps, boost control and a 4 bar map sensor. the quality and service were spot on.
Note: This is not an advert. I have no connection with ExtraEFI. Simply aware that a lot of PFers are trying the MS route but struggling with supply.
Doug.
Doug.
DEYTUKURJERBS
260quid? Hmm, maybe EFi V8 Turbo is a good idea after all?
12x12 map? How tiny is that? I dunno. I mean, i still need an ECU for the GTR too...
And the S13 would be nice too...
What gets done with regard to loom etc?
I freely admit electronics and ECUs confuse me, hence my love of blow thru carbs
144 sites will be adequate as long as you set them up correctly.
As for suitability for V8s, Phil is your man. He runs a 5ltr TVR V8 with 8 x throttle bodies on MS in his cobra.
A short labled loom is supplied with the ECU. Basically just hook it up to your sensors. Very easy.
I agree that you can probably do "enough" on most basic engines with 12*12, but its not really ideal when you are using MAP vs RPM imho.
Better if you didnt have to make the sacrifice of less resolution in certain parts just so you can have it where you need it most.
for 260 quid though, you really cant complain
Be interesting to hear Stu's view on the old MegaSquirt.
I've got a Megajolt I've been dying to try out as a replacement for my old Lotus Twin Cam Dizzy..... but have been a little nervous as many seem to scoff a the old MegaJolt/Squirt thing as if its some sort of a toy.
I'm not saying its the best ECU in the world, but it can certainly hold its own i the sub £1000 catagory.
and for £260 there really is no excuse to be running jetronic on a tuned RS Turbo!
DEYTUKURJERBS
1 Post
Stu wont touch them to be fair, i cant blame him, he dont know who built up the system or anything, he dont want to be held responsible.
Im going this route for my twinky turbo so i can use 4 injectors and coilpack
Originally Posted by Rick
To be honest, 250 quid or 500quid, doesnt make much differene in cost. You still need somone to map it, and that costs.
The attraction of this piece is for those interested in doing their own mapping anyway IMO
Originally Posted by Rs1
So who WILL map the Megasquirt? Anybody on here cuurently running MS,and at what state of tune?
Rob
Rob
Ive not mapped on it yet, but will be doing an N/A car on it in the next few weeks, so will post what i think of it compared to other ECU's ive mapped with.
I know Stu wont neccessarily map one, but would be interested to hear his view on whether the 12x12 spark, 12x12 fuel is enough and is the sampling rate of the processor enough etc.
I think the boys at Northampton Motorsport will have a crack at one.....
Morning Fellas,
As has been stated, we wont map a megasquirt under normal circumstances, and this is NOT because we think there is anything wrong with it, but rather because we are not happy about the build quality problems we have seen over the years and ultimately decided to no longer support it.
The problem immediately apparent is a LOT of them are assembled, at component level by people who do not know how to solder or understand the basic techniques required to make the components connect reliably.
Can you imagine the result a poor joint would have on the injector driver itself? Low current to one injector, maybe only when teh ecu is hot?
And who would be blamed if one cylinder detted itself to destruction?
Yes, always the mapper.
12x12 has to be considered a bare minimum for good modern mapping without too much compromise, although i would far prefer 16x16.
Here are some basic Marelli maps to give you an idea what you would get from your available size.
13x16
http://img.photobucket.com/albums/06...g/e4ccf101.jpg
8x16
http://smg.photobucket.com/albums/06...t=f905fb74.jpg
13x16
8x16
I agree, if there are issues with the build quality, fault finding can be a pig and take hours.
All the ECUs Phil builds are tested on his unique test bed, the same one the code was developed on, and then soak tested under load for a minimum of 12Hrs. The PCB is then coated in laquer to protect it.
I will only buy fully built ecus from Phil because of the reliability that he has introduced and quality control he uses.
Originally Posted by GARETH T
im not bad on the old soldering iron,, i would i pay the extra to have a fully tested unit
They great from Phil.
He asks what you want it for and then specs the setup to suit you.
The kit comes with a nicly done short loom and all cabling and software
I payed 260 for mine
Sadly doug, most people would sooner have a shitty one nailed together for 200 than a decent one for 260.
PassionFord's crazy fool!
Stu, maybe you could map the ones done by this Phil guy if people have a proof of purchase from him?
Would probably need to see some kind of testament to their reliability over time though.
As it is, im sure the last thing he needs to be doing is entering the budget end of the tuning market.
I cant see people wanting a top quality MSD livemap for 600 quid on their 260quid ECU very often.
Would be a better thing for someone else who isnt already one of the countries leading tuners to get invovled in, like Doug
Originally Posted by SafeChav
I may have a go with one of these
First time for everything as they say unchballs:
Originally Posted by OvaBoost
Think my dad helped with this article in fast ford down at mech motorsport
