Saff damp boot?
Old May 24, 2006 | 10:06 AM
SPADGE's Avatar
SPADGE
Default Saff damp boot?
Hi all
The boot in my saff gets very slightly damp when left outside in hard rain.
The boot seal looks in good condition and not torn.
I know saffs have a problem with this but where is it most likely to be getting in?
Cheers Spadge...
Old May 24, 2006 | 10:08 AM
Ive seen that when the roof gutter drains are perished.
Where abouts in the boot does it get damp specifically?
Old May 24, 2006 | 10:09 AM
SPADGE's Avatar
SPADGE
It gets damp near the rear panel mainly on the passenger side.
Not a lot but enough for me to want to sort it.
Old May 24, 2006 | 10:11 AM
maxest's Avatar
maxest
Rear lamp gaskets.....
Old May 24, 2006 | 10:12 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Spadge,
Light cluster seal
or
When the boot is open, about four inches from the back of the car along the top of the rear wing (in the gutter to the left of the rubber seal), check the joint there ? I think there's a weld there, if the wing isn't original, it could have been badly repaired
I hope the above makes sense
Old May 24, 2006 | 10:14 AM
RS500/364's Avatar
RS500/364
had that a couple of time swap sides and turn them around makes a good seal !!
or the rear window
Old May 24, 2006 | 10:16 AM
SPADGE's Avatar
SPADGE
Thanks for the advice
I suspected the rear light seals could be the problem and will remove them and reseal them using a small amount of silicone is necassary.
Frog - there doesn't seem to be any problems with welds but cheers for the tip
Old May 24, 2006 | 10:45 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
hmmm i seem to have lost my reply i typed...
anyways i get this too but had suspected the middle mount of spoiler to the boot because its rusting a bit. i shall check the light gaskets instead. cheers
Old May 24, 2006 | 10:54 AM
Csm's Avatar
Csm
Aye ive had this with a few sierras over the years , rear lamps out ,clean up and re-seal using silicone ,works a treat for me
Old May 24, 2006 | 11:09 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
i had that prob.. it was the rear light seals so i used two on each side,gives more adjustment without leaving a gap! i hate silicone!!
Old May 24, 2006 | 11:12 AM
Stu @ M Developments's Avatar
PassionFords Creator
Ditto that.
Buy new seals, pennies from Ford. Dont use botch it silicunt.
Old May 24, 2006 | 11:16 AM
SPADGE's Avatar
SPADGE
Ditto that.
I didn't expect new gaskets to be available but if they are then of course i will use them in place of silicone Stu
Old May 24, 2006 | 11:18 AM
Tom Baxter's Avatar
Tom Baxter
Stu you get worse mate must be the petrol fumes.
Old May 24, 2006 | 11:20 AM
Eh? Why?
JTECH James
Passion for Fords!
wow wow........ dont smoke near perol fumes
HEALTH AND SAFETY
Old May 24, 2006 | 11:21 AM
SPADGE's Avatar
SPADGE
I'm lost here what the fook are the last 2 replys about
Old May 24, 2006 | 11:22 AM
Fook knows mate!
Old May 24, 2006 | 11:23 AM
JTECH James
Passion for Fords!
i think tom baxter was refering to the silicunt comment....... though it is a common motor trade term
I was commenting on toms comment... petrol fumes
Old May 24, 2006 | 11:24 AM
gingeRS's Avatar
gingeRS
Ditto that.
the escort ones (mk4 rs turbo) only cost 3.50 ish, and i kow you can still get the sierra ones. wouldnt expect them to cost any more
Old May 24, 2006 | 11:29 AM
Ah, maybe he thought i was calling Spadge a silly cunt!
Old May 24, 2006 | 11:32 AM
SPADGE's Avatar
SPADGE
Where you
Old May 24, 2006 | 11:33 AM
JTECH James
Passion for Fords!
i thought the c word was banned
Old May 24, 2006 | 11:38 AM
SPADGE's Avatar
SPADGE
Old May 24, 2006 | 11:54 AM
Where you
Dont be silly you daft Cunt.
Old May 24, 2006 | 12:08 PM
rscozzysie's Avatar
rscozzysie
i had a leak in my boot changed rear light gasket and no more damp boot
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
