how do i reduce kb on this?
i need it to be smaller so i can use it on the new garage section
anyone tell me how or fancy doing it for me?
this is the size of it on my computer
size 398 KB (408,573 bytes)
size on disk 400 KB (409,600 bytes)
You may attach an image.
Maximum file size : 350 kbytes
Maximum resolution : 1024
If you go into the picture on your PC. Right click, edit, you can then alter the size using Paint or smiliar. I normally use Stretch and Skew.
Would do it for you mate but my work PC hasn't got Paint.
cheers guys , ill give it a go now.
as for linking it to photobucket, i tried that and it wont have it saying it dont support the file type
something tells me i shouldnt be doing it,
ive reduced size
size 316 KB (323,840 bytes) and its still saying
Image Upload Threshold
The Upload Of The Image Failed Because Its Size Was Greater Than That Allowed By The Administrator. Please Try Upload The Image Again With A Smaller Filesize.
If You Were Creating/Editing A New Vehicle/Modification/Quartermile Time/Rollingroad Run It Will Still Have Worked, However The Image Will Not Be Attached To It
ive reduced size
0-60 in 17 seconds (eek)
3dr cossie
21
20-11-2015 05:00 PM
markk
23-08-2015 09:57 PM
