injector help please
Old May 14, 2006 | 01:45 PM
Gary Osborne's Avatar
Gary Osborne
Default injector help please
tryin to get some injectors from the states for my cossie. the resistance on them is 2.8 ohms just wonderin if this will work on my cossie? oh and there 72 lb injectors..... think this is around 750cc but maybe somone can enlighten me thanks
Old May 14, 2006 | 01:57 PM
DazC's Avatar
DazC
Easiest thing to do is this...
Get a multimeter and set it to ohms.
Unclip one of your injector plugs and put the 2 multimeter leads on the 2 terminals.
Take a reading.
It should be around the same give or take a few ohms...
Old May 14, 2006 | 01:58 PM
2.8 ohms should work fine on Cossie management.
Old May 14, 2006 | 02:02 PM
scruffythefirst's Avatar
scruffythefirst
yup, 750cc ish
Old May 14, 2006 | 07:56 PM
Gary Osborne
thanks for the replies lads .... anyone know if these will work with an omex 600 unit
Old May 14, 2006 | 08:06 PM
Garage19's Avatar
Garage19
I suspect you may need to use ballast resistors with them on omex.
Old May 14, 2006 | 09:42 PM
capri-rs's Avatar
capri-rs
does the omex support high or low ohm injectors??
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
