anyone good with electronics? (resistors)
Old 11-05-2006, 08:15 PM
Wazzzer
Wazzzer's Avatar
Default anyone good with electronics? (resistors)
I'm putting the bike up for MOT soon but I've replaced the standard repeaters with mini ones and the flasher rate is too high
I know I can put a resistor in the + wire to reduce the rate, but how do I work out what rating resistor I need?
Thanks for any help
Old 11-05-2006, 08:28 PM
RS ONION
RS ONION's Avatar
not to sure as im putting some on mi car , but i have heard that u can measure the resistance on ur standard bulb then it can be worked out wot resistor u need, but not sure which one yet?
Old 11-05-2006, 08:34 PM
AlexF
AlexF's Avatar
put a vaux nova/astra flasher on...
problem solved!
Old 11-05-2006, 09:15 PM
Wazzzer
Wazzzer's Avatar
problem solved!
sorry if I'm being thick but I don't get what you mean...
Old 12-05-2006, 12:22 PM
nthorpey
nthorpey's Avatar
you can also just buy some new bulbs with the same wattage rating as the originals to correct the flash rate
dombanks
21-09-2015 08:38 PM
markk
09-09-2015 08:11 AM
turbowag
03-09-2015 08:07 AM
Quick Reply: anyone good with electronics? (resistors)
