SECS s8 and RP Lab
#41
Caraholic
The first batch of RP lab items will be rolled out to the tuners first and once these are in place, it will then be offered out to general public.
Once these have been on the market for a while, then the P8 version will then be rolled out along with an eight injector upgrade for the L8.
#42
SECS ECU's are probably best sourced secondhand NEW NEVER BEEN USED at the moment, like from RS500/104 up above
The RPLab one is only for L8 AFAIK, so if you have any other ecu you will need to upgrade to an L8 first.
SO WHAT I WOULD BE ABLE TO DO IN TIME IS RUN L8 THEN IF I GO TO A P8 I CAN JUST TRANSFER THE MAP CORRECT ?
#44
Well thats kind of true mike, you could pretty easily copy your L8 map accorss manually and just interpolate by putitng values midway between where the points are different.
So you could certainly use the L8 map as a very good basemap on the P8 at least
#48
Just don't enter the wrong figure when extrapolating - got to be asking for trouble with chubby fingers .
Mike, those of us used to mapping wouldnt have a problem, and in your case, you could pay harvey to do it for you
#51
Don't worry, I would NEVER attempt any mapping at my current knowledge level .
#52
Sponsor
locking it whos got the right to lock it it isnt the tuners product or software , can understand it if a tuners his ptotecting his software in the ways of building the chip and licenced to that company . so is this ecu going to be sold by a tuner going to be licenced to them and them only ?
If i was going to pay 850.00 for a 15 year old ecu which is upgraded (i might add a clever one ) as karl bangs on about how good the weber is and rightly so, id want know that at any time if theres a prob with it in can be accesed without having to go to the first tuner that set it up! but if its licenced the so be it,
by the way this is my opinoin not a dig
