Maxtourq brake discs ???
thanks peeps, they are for my stage 3 saph cos and seem cheap as chips
think ill try them
what pads u runnin in ur cortina ?? assuming ur running sierra gear ?
think ill try them
they are cheap, defo. Ive just put some black diamond discs on, and they are doing really well. Ive had smoke totally pouring from the pads, and they still straight as. But, for 50 quid, i'd try em. I'd use a mintex or a ferodo pad.
i used the black diamond combis and pads on my previous st24 mondie and they were awsome compared to standard ones
just saw the fact the maxtourqs were half the price even for the combi versions !! and after replacing the clutch and turbo im el-skinto
The guy I spoke to at Rally Design said for road use the Maxtorq discs are cool and will with stand plenty he did advise, as people above have said, to go for a better pad like Mintex (which I did) he told me that the Mintex pads are just the same as the EBC green stuff pads and are spot on.
For a budget set of discs I can't fault them.
HTH
HTH
I used maxtorq brake discs & mintex pads before i upgraded to a 330mm brake kit, i would deffo buy maxtorq discs again they are an excellent bit of kit for the money, no problems with warping.
Simon.
Simon.
Used a couple of sets of these on the Cossie, were fine, just don't expect too much. If you use them "properly" the usual cracking appears.
As I've told you before don't go for drilled.
