CHIP REQUIRED
Old Apr 30, 2006 | 11:54 AM
costina's Avatar
costina
Live long and prosper!!
Default CHIP REQUIRED
To run light greens (355's) on a 3 bar map sensor
Can anyone help please?
Old Apr 30, 2006 | 11:57 AM
RS500/364's Avatar
RS500/364
you might want to put on what ecu and turbo !!!
Old Apr 30, 2006 | 12:00 PM
Jim Galbally's Avatar
Jim Galbally
www.motorsport-developments.co.uk
Old Apr 30, 2006 | 12:09 PM
costina's Avatar
costina
Level 6
T34/48 stg 2
pace cooler
polished head
otherwise standard
Don't want to spend a fortune as its my daily driver(2wd saff)
oh and a superchip phase 1
Old Apr 30, 2006 | 12:21 PM
RS500/364's Avatar
RS500/364
NOW THATS A JOKE I THINK EVERYONE ON HERE TOLD THAT ONE!!!!
Old Apr 30, 2006 | 12:30 PM
costina's Avatar
costina
JUST A CHIP NOT A Ł500 SET UP
TIME'S ARE HARD AT 99.9 PENCE PER LITRE(opitmax)
Old Apr 30, 2006 | 12:31 PM
Stu @ M Developments's Avatar
PassionFords Creator
Cheapest option is to have a tuner set it up for you on what you have as the 355s are virtually no different to standard.
Old Apr 30, 2006 | 12:43 PM
costina's Avatar
costina
Cheers Stu, just don't like the guessing after 14.5 psi
Thinking its not that good, what's the max boost on this set up ?its 0n 18 psi on the secs monitor How can this b when map only reads up to 1 bar? any info would be gratefully received
Thank you
Old Apr 30, 2006 | 12:52 PM
Sadly, the answer to this question is complex and not at all possible in one line, but the nutshell is simple, the top line in teh fuel map is mapped for the amount of boost you plan to run. If its mapped for say, 20, it will still access it at 14.7 and be slightly rich until teh boost reaches 20.
Its no different to running 38psi on a 3bar map sensor.
Incidentally, if you run a 3bar map sensor on a std 2bar mapped chip, say goodbye to your pistons in teh very near future.
Old Apr 30, 2006 | 02:59 PM
costina's Avatar
costina
Stu, would you do me an off the shelf chip to be more accurate than the one i have using a 3 bar map ?
Old Apr 30, 2006 | 03:28 PM
Alvyn's Avatar
Alvyn
why not just take the 3bar off get a 2bar set the fuel etc and use a stage 1 chip?
Old Apr 30, 2006 | 03:41 PM
costina's Avatar
costina
I am not using a 3 bar (i want too)
Still want 290/310 bhp but don't want 803's
On my 355 set uses a 2 bar map which is (old skool) after 14.5 psi it runs rich untill top boost is reached 18/20 psi i want it more accurate .
Old Apr 30, 2006 | 03:59 PM
Alvyn's Avatar
Alvyn
well my m8's IS on a stage 1 chip(upto date one) which is running with a 2bar 18psi on 355's and running 298 bhp and doesn't have any leaning off issues
Old Apr 30, 2006 | 04:14 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
If you want economy Paul buy a diesel
Hope you sort what you want
Steve.
Old Apr 30, 2006 | 07:13 PM
costina's Avatar
costina
Who's chip is he using?
Old Apr 30, 2006 | 08:56 PM
Jim Galbally
do it once, do it right
speak to stu or kenny on the phone first thing tuesday, you'll only get the RIGHT advice. you wont be sold anything you dont need
Old Apr 30, 2006 | 09:06 PM
costina's Avatar
costina
Cheers jim for the advice, would like closed loop coil pack and a set up on both cars
So it will just have to be a chip change for now
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
20/20 vision
Sep 29, 2015 09:25 PM
