Cossie Mng parts - need help
Old 04-08-2004 | 12:35 PM
EssexBoyRacer's Avatar
EssexBoyRacer
Default Cossie Mng parts - need help
Just looking and pricing up the bits I need.
Can anyone tell me if this is the right FINIS code for the ignition amplifier -1637546 Also I need a heatsink!?! - cant find it.
If i wanted to use my existing ERST throttle body where do I get one of these remote idle control housings from? Are they on the xr2is?
Cheers!
Old 04-08-2004 | 12:44 PM
zvhturbo's Avatar
zvhturbo
The remote idle valves were fitted to XR2i and XR3i (EFI models)
The XR3i's had a carier to hold it by the fuse box as well so will be worth getting that as well.
They are about £130 from fords and about £5 from a breakers.
They typically clog up with oil etc so will need a good clean.
Sorry can't help with finis code for the amp
Old 04-08-2004 | 01:12 PM
danvisteon's Avatar
danvisteon
the efi idle valve doesn't work with cossie management, you can by them from webcon or find a lancia breakers and get one of an intergrale or croma turbo as they are the same idle valve as a cossie and are mounted remotely, i hope this helps
Old 04-08-2004 | 01:16 PM
EssexBoyRacer
but the cossie idle valve would work in a xr2i / xr3i remote housing?
Old 04-08-2004 | 01:19 PM
danvisteon's Avatar
danvisteon
i doubt it buddy i belive they are two different sizes, i have got a cossie throttle body if you want it, which has been configured for a series 2 ( inner shaft turned round so that throttle pot does not hit rocker cover) let me know i can bring it tonight to the pf meet if your'e coming
Old 04-08-2004 | 01:20 PM
EssexBoyRacer
cheers for offer dude, will bear it in mind but thats what Im trying to avoid - cossie throttle body turned on its side. Dont like how they they look.
Old 04-08-2004 | 01:22 PM
danvisteon's Avatar
danvisteon
ok mate no probs, just bear it in mind if all else fails
Old 04-08-2004 | 02:26 PM
EssexBoyRacer
is this where the idle control valve is on xr2i plenums?
Old 04-08-2004 | 02:29 PM
danvisteon's Avatar
danvisteon
yep and on xr3i's they are on the o/s wing, and looking at that picture the cossie idle valve is loads bigger
Old 04-08-2004 | 02:42 PM
Scott R's Avatar
Scott R
I have got the remote housing for the cossie ISCV, shall we say £20
Old 04-08-2004 | 02:47 PM
EssexBoyRacer
lol im getting confused here. if wanted to mount the cossie iscv where I've circled in the pic I would need a different housing? I thought the cossie ones were mounted in the throttle body?
Old 04-08-2004 | 02:57 PM
danvisteon's Avatar
danvisteon
do you want me to give you a ring to explain
Old 04-08-2004 | 03:00 PM
EssexBoyRacer
aye that would be handy dude! But Im bit hounded at work today, are u at the meet tonite? can pm me no and meet up for chat?
shame u still aint got u're's i'd like to have had a look how its done.
Old 04-08-2004 | 03:13 PM
danvisteon's Avatar
danvisteon
hold on here's a pic
it's beside the crossover pipe me mobile number is 07810742513 just look for a black M3 with the reg L38FPJ i should be near that or look for cossienuts coz i will near that lot
Old 04-08-2004 | 03:22 PM
EssexBoyRacer
lol, that is nothing like the one in my pic!
u've kept the escort throttle body too!
Old 04-08-2004 | 03:26 PM
Jon ERST S2's Avatar
Jon ERST S2
I'll post some pics up when I get home. You want a remote one (thats on a 90 degree bend)
Old 04-08-2004 | 03:28 PM
EssexBoyRacer
so the remote ones from a xr3i will take a cossie iscv?
Can u not use the one as I pictured?
Old 04-08-2004 | 04:10 PM
Jon ERST S2
no you need the housing from the lancer.
Best bet go to a breakers and get the sensor/housing I got mine for a tenner. I believe the actual iscv is teh same one so you can use a cossie sensor on the lancer housing (as it's the same sensor)
Old 04-08-2004 | 04:16 PM
EssexBoyRacer
gotcha!
cheers dude!
155lee
06-09-2016 12:10 PM
Bransby
14-09-2015 09:54 PM
Quick Reply: Cossie Mng parts - need help
